Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > PowerAcoustik 2300W RMS/3000W & 2 pio...
Author Thread: PowerAcoustik 2300W RMS/3000W & 2 pioneer 750rms/2000max
Username: Forcesofchaos
ok so i want to get those things
The amp
PowerAcoustik A3000DB 3000 Watts Class D Series Amplifier
First if i get this i can connect two subs to it making it work at 2ohms which i want giving me
1800W @ 2Ohms
Specifications:
# Hi Speed Digital Circuitry
# Fully Regulated PWM Power Supply
# Four Way Protection
# 1 Ohm Stable Stereo
# Bridging Synchronization
# Remote Dash Mount Low Level Gain Control With Cable
# System Distress Indicator
# Dual Mono Speaker Output Connectors
# Gold Plated Heavy Duty Power & Speaker Terminals
# 1100W @ 4Ohms
# 1800W @ 2Ohms
# 2300W RMS/3000W Max
# Frequency Response: 15Hz to 150Hz
# S/N Ratio: 100 dB
# THD: 0.5%
# Variable Low Pass 50Hz-150Hz
# Variable Subsonic Filter 15Hz-40Hz
# Variable Subwoofer EQ @ 45Hz
# Phase Switch: 0-180
# Inputs Sensitivity: 200mV-8V
# Dimensions (L x W x H): 16.8" x 11" x 2.3"
well from the way it sounds it also has ports for rear and front speakers or something or would i have to get a seperate amp <:-(> well ok..
2) now thats a lot of power.
can i get a 4 gauge amp kit and it will work with it even say if it was 8?
will my car handle all this power the speakers i have in it now are somewhat new or something i dont anything about them but i know they are pretty good and they didnt come wiht car my granpa bought them.
The car is 1990 , pontiac, bonniville. one of those older looking cars.
well i havnt looked in manuel to see alternators power but well this stuff work.
do i need another amp <omg> for the speakers or what thanks.
Heres the amp kit i want
* 4 ga. / 20 Ft. Clear Red Power Cable
* 4 ga. / 3 Ft. Clear Black Ground Cable
* 12 ga. / 33 Ft. Clear Speaker Cable
* 17 Ft. Blue Turn On Cable
* 17 Ft. Shielded Clear Blue RCA Cable
* AGU Fuse Holder With 60A AGU Fuse
* Complete Accessories
* Double Clamp Blister Packaging
Also im going to parrell connect the subs if i get this stuff im gona order maybe in a few days if everything works out.
i found amp for 300$, 2 subs togther for aobut 220$ total of 525 + 40$ <shipping>
Maybe a capacitor i dont really wnat to spend alot more any help would be apreciated thanks.
Dont mean to double post but forgot to mention a few things.
The 8 gauge kit comes with a 40A fuse so maybe it does matter, what kit would suit me?
subs
Pioneer TS-W2000SPL 12" Premier Subwoofer
# Interlaced Carbon Fiber / Glass Fiber Reinforced IMPP Cone Woofer
# Wide-Roll, 3-Layer Fiber Woven Radial Surround with Honeycomb Cloth
# Double 4-Layer, Long Voice Coil (2 x 4ohm)
# 4-Slit Glass Imide Voice Coil Bobbin
# Conex Damper with Damper Ring
# Projected Pole Yoke with Vented Pole
# Double Stacked Magnets (110 oz.)
# Thick 7/8" (20mm) Top Plate
# Aluminum Die-Cast One-Piece Rigid Chassis
# Silver Binding Posts
# 1-Piece Rubber Gasket
# 750 Watts RMS/2000 Peak Power
# Dual Voice Coil Design (2ohm or 8ohm)
# Frequency Response: 18 - 2kHz
# Sensitivity: 89dB (1W/1m)
# Recommended Enclosure: 1.5 Cubic Feet
So thats those two, i need to find a box too havnt looked at any, know of a good place maybe.
for the capitor couldnt i just get like a 2.4 farad capacitor?
that should cover it i dought ill ever go over that man watts 2400 thats more then the rms and a little under the max but even if i do im sure the alternator could supply a little power maybe?
maybe i need nothing i dont know.
Like this capacitor
PowerAcoustik PC2.4FN Digital Capacitor
* Digital Power Capacitor
* 2.4 Farad
* 24 Volts DC
* Digital Display
* Satin Plated With Cover
* Mounting Brackets
http://www.etronics.com/product.asp?stk_code=powpc24fn&rpc=299&catid=309&store=
Thanks again
im kinda new to this stuff.
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > PowerAcoustik 2300W RMS/3000W & 2 pio... [ « Previous ] [ Next » ]
