Thread: What deck to buy for my toyota camry 02? |
| Posted on Monday, September 20, 2004 - 12:37 pm: |
hi pplz im changing my head unit for a camry and i want a full deck as in a cd am/fm and cassette player i want to hook up my amp to it as well so i want those line out jacks in it for the front and back speakers. |
| Posted on Monday, September 20, 2004 - 12:40 pm: |
forgot to tell you guys that my price range is up to $120 max i just want a better sounding deck other than my toyota deck. |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 141 Registered: May-04
| Posted on Monday, September 20, 2004 - 04:18 pm: |
Well your not going to find a radio that going to fit your car for 120. You only have a single din opening which means the radio is smaller fr your car if you had a double din the price would be much cheaper. but I found one for $224 Heres a link to a site that has the perfect radio for you. http://www.sbhcorp.com/scripts/homeViewItem-76.html Good luck |
| Posted on Monday, September 20, 2004 - 04:50 pm: |
Thanks joseph but that is too expensive since i have to spend so much for wat i want then i'll just go with a cd am/fm only no cassestte i just want to be able to hook up my 4 channel amp to it without any problems. |
| Posted on Monday, September 20, 2004 - 04:53 pm: |
sorry to tell you the wrong model of car it was ment to be a camry 2001 not 2002 |
