Home > Message Board > Car Audio > Head Units > Archive through October 04, 2004 > Need a wiring diagram for the stock r...
Author Thread: Need a wiring diagram for the stock radio for a 03' Mitsubishi galant
Im replacing the stock radio with a new sony unit and i need to know which wires go where. I think i figured out the speakers but not sure where the last 5 go, is there somewhere online i can get a wiring diagram for that? Thanks in advance. - teamhooligans@yahoo.com
Username: Ps1k0
Post Number: 23
should have gotten a wiring harness. they are inexpensive and you would have been done by now.
you can check on www.installdr.com for the wiring.
Home > Message Board > Car Audio > Head Units > Archive through October 04, 2004 > Need a wiring diagram for the stock r... [ « Previous ] [ Next » ]
