Thread: Quick What is the best performing Cheapest amp? |
New member Username: Wrestlertreece
Post Number: 9 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 06:07 pm: |
What is the best performing, hardest hitting, cheapest amp that i can get? |
Silver Member Username: A3forme
Post Number: 179 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 08:16 pm: |
Well, amps don't hit hard...subs do. You can't suggest an amp unless we know what subs you're gonna use, and what your budget is. Hit us up w/ a little more info. |
Bronze Member Username: Wrestlertreece
Post Number: 12 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 09:36 pm: |
OK i'm just lookin for a cheap system..i need to know what is the bust amp for the price... plus what kinda subs ya'll would suggest..thx dont you hate newbies? |
Bronze Member Username: Hifonics
Post Number: 18 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 11:05 pm: |
how much do u want 2 spend then we can tell u
Post Number: 19 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 01:19 pm: |
i'm wanting to spend probably at most 400 dollas on the amp thx |
Bronze Member Username: Decde
| Posted on Monday, September 20, 2004 - 01:28 pm: |
Jeez, that isn't that cheap :P The mtx thunder series are quite good, check off ebay, u usually ind so nice one's for sale |
Post Number: 20 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 01:58 pm: |
is there any sites that i might be able to take a look at them and what watt would u recomend thx |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 136 Registered: May-04
| Posted on Monday, September 20, 2004 - 03:09 pm: |
heres a nice system fro you 2 12 inch kicker comp vr's at $74 a peice on ebay and a jbl bp600.1 for $175, that leaves you with a lil under 80 bucks for a box and wiring kit |
| Posted on Monday, September 20, 2004 - 03:52 pm: |
Joseph...he said $400 on the amp, not everything yo. Jacob...you've got like 50 different posts asking the same questions....pick some subs....THEN pick the amp to power them.
Post Number: 22 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 04:20 pm: |
anonymous guy..i'd rather have my amp first so i know that i got the power to push my subs..and to know how good of subs i need.. |
Silver Member Username: Heavyb
Hopkins,
Sc
Usa
Post Number: 125 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 04:38 pm: |
for 400 probably the best amp with them most power would be a mtx 1500d. alot of power and get what they are rated for. could get awsome subs with this much power. |
Post Number: 23 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 04:48 pm: |
thx blare i'll look into that
Post Number: 203 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 04:49 pm: |
I'd have to go with Anon....pick out the subs you want first. That's where the sound is going to come from. Then you pick the right amp to power them. If you buy your amp first...then you're limited to what you can get for subs... For instance. The MTX 1501D puts out 1500W at 2ohms....it's great so you buy it. Now, you find these subs that are just killer and you want 2 of them. But, they are 4ohm dual voice coil and 800w rms. They can only be wired at 1ohm or 4ohm. Now your screwed because the MTX 1501D doesn't go up to 1ohm and only puts out 750w RMS at 4ohm. (not enough to power your subs) Now you've either got to find another sub or return your amp. I would always pick my sub first. |
Post Number: 24 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 04:52 pm: |
ok, i'll take your advise but i cant get to big of subs to fit into my 1969 el camino now can i? |
Post Number: 206 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 05:02 pm: |
I think this is the first time you've ever mentioned what vehicle you'll be using. Regardless....get the best sub within your size restraints and then pick the best amp to power it. Adire Koda 10" subs are are good sq/spl subs for trucks w/ limited space.
Post Number: 25 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 05:07 pm: |
ok thx...Mazda i see u postin stuff everywhere where do u get the time man? |
Post Number: 209 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 08:46 pm: |
It's called internet access at work!  |
Post Number: 30 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 08:55 pm: |
lol.. U must spend lot of time doin it.. i mean i get on it during 2 classes during school...but no way i know as much as you do bout this crap.. heck i dont even really know what a ohm is..but thats why i'm tryin to learn somethin before i go and hook up a $$$$ system |
Silver Member Username: Koz1031
Monticello,
In
United states
Post Number: 141 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 09:01 pm: |
a 69 EL CAMINO It must really suck to have to drive a half car half truck. Tell you what. Why don't you just give it to me, that way you can buy another vehichle, that would be a lot easier to fit this stuff into. There is no sense of a newb having to go through this, in that type of automobile. |
Post Number: 34 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:03 pm: |
PHHH screw you buddy! my El Camino aint never lost a race.. and aint gonna start..she's my shaggin waggon.. Mess with the best get smoked like the rest! |
Post Number: 212 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:07 pm: |
Well, I don't think Koz meant any harm. He just means your vehicle is against you, in terms of flexibility, when you're looking at this stuff. |
Post Number: 36 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:10 pm: |
I know but i'll fit if i have to tear out the seats and make my baby ride on my lap.. hey thats a good idea..  |
Monticello,
In
United states
Post Number: 146 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 09:39 pm: |
serious Jacob, I was paying you a compliment. Haven't seen the car, but that's a nice ride. As far as audio goes it's gonna be hard to fit stuff inside. Let's face it, They are built tight. And that's good as far as the car goes. As far as never losing a race, I believe that. But GLASS has a ride of his own, you may not want to go up against. AGAIN!!! just joking around. You may want to go shallow mount free air subs, that should fit under the seat. Hell your "baby" would even like that. LOL watch her smile to the beat of the bumps. LOL. Subs are gonna be hard to find, the rest is pretty easy. I know there are others but eartquake makes a hell of a shallow maount sub, and jonathon has mentioned a couple of others, but I don't recall who made them. Have fun, and sorry if I offended you. It wasn't intentional. |
Post Number: 38 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:45 pm: |
Yo, Koz i was just jokin to...but i would sell my baby for a perty penny ....U didnt offend me any i was just givin you crap.. I LOVE my car.. somebody told me somthin like Infinity had some pretty slim subs... |
