Thread: How is the Boss PD4000 |
New member Username: Wrestlertreece
Post Number: 3 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 04:57 pm: |
I'm lookin to buying the buss PD4000 but i was wantin to know how good it was first...And what modifications would i need to make to my car so i wouldnt blow anything..?thx guyz |
Post Number: 8 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 05:30 pm: |
guess nobody knows or nobody cares.... |
Silver Member Username: Heavyb
Hopkins,
Sc
Usa
Post Number: 121 Registered: Jul-04
| Posted on Sunday, September 19, 2004 - 06:07 pm: |
dont get it its a peice of junk for the money u can get somerhing better how much do they run and i will tell u something better for the money. |
| Posted on Sunday, September 19, 2004 - 08:32 pm: |
It blows |
BigYellowTaxi Unregistered guest |
| Posted on Sunday, September 19, 2004 - 08:33 pm: |
Yeah, boss isn't so hot |
Silver Member Username: A3forme
Post Number: 180 Registered: Sep-04
Poor realiability, severely over-rated, not advisable. |
Bronze Member Username: Wrestlertreece
Post Number: 11 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 09:28 pm: |
its bout 300 dollars on yahoo shopping at Ultimate-sounds.com its like $419 |
Post Number: 13 Registered: Sep-04
| Posted on Sunday, September 19, 2004 - 09:51 pm: |
How are Deisel Amps? |
Hopkins,
Sc
Usa
Post Number: 126 Registered: Jul-04
| Posted on Monday, September 20, 2004 - 04:41 pm: |
for 350 well actually less u could have something like a mtx 1500d wich gives what its rated and will power almost anything u throw at it. |
Post Number: 27 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 05:25 pm: |
tell me where i can find the MTX 1500d at...will yu? |
Gold Member Username: Its_bacon12
Hfl,
Ny
Usa
Post Number: 1016 Registered: Dec-03
| Posted on Monday, September 20, 2004 - 07:57 pm: |
hmm id go with a kx1200.1 or bp1200.1 instead of the thunder1501d theyre much more flexible with different impedance levels especially the bp1200.1 |
Post Number: 28 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 08:05 pm: |
ok thx i'm still tryin to check these things out.. i mean i'm kinda limited on space..till i get a bed cover... |
Post Number: 29 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 08:36 pm: |
OK... Now can someone tell me what is better the Thunder 1501 or one of those 1200.1's that its__bacon was talkin bout?????? |
Post Number: 210 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 08:57 pm: |
Um....well. The JBL 1200.1 is a little more flexible in that it can produce 1200W at 2 or 1ohm. KX1200.1 just has different specs 300wx1(4ohm), 600Wx1(2ohm), and 1200Wx1(1ohm). I wouldn't say it was more "flexible" The MTX in my opinion has an advantage as it puts out more power @ less resistance. 750W(4ohm), 1500W(2ohm). Just depends on the application and what subs you get. That's why I say Jacob....AGAIN....pick out your freakin subs FIRST!!! Then get the right amp. How do you plan on setting the subs up in you '69 El Camino?
Post Number: 32 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:00 pm: |
Its called a truck bed with a cover and a hole in the back of the car with some selant for no leaking..lets just say i may not know much bout stero equipment for being 15 but i am one hell of a mechanic! |
Hfl,
Ny
Usa
Post Number: 1019 Registered: Dec-03
| Posted on Monday, September 20, 2004 - 09:50 pm: |
ok well still doesnt giev a reason y u shouldnt pick out your subs first |
Post Number: 39 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 09:53 pm: |
I know bacon.... i already got my stuff picked out i think... I think i'ma get a couple of Shivas and couple of MTX 12's.. i'm sure u all know more bout audio then me so i'm takin your advice... |
| Posted on Monday, September 20, 2004 - 11:46 pm: |
jacob....if i where you i'd go w/ a pair of shivas and a JBL BP600.1...or if you have room 4 shivas and a BP1200.1. that would be a good setup. |
Post Number: 43 Registered: Sep-04
| Posted on Monday, September 20, 2004 - 11:52 pm: |
You dont think the MTX 1501d will do a good enough job or u just recomend JBL? |
Post Number: 221 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 09:57 am: |
Truth is the MTX 1501d wouldn't power 4 of them properly, and for 2, it would be too much power. If you want 2, stick with the Kicker KX600.1 or JBL 600.1. If you want 4 use the JBL BP1200.1 or Kicker KX1200.1 Do not try to power 2 Shivas and 2 MTX subs off the same amp. If you want to run 2 differen't kinds of subs, you need to use 2 different amps IMO. |
Post Number: 46 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 01:13 pm: |
ok thx..do you compete Mazda? |
Post Number: 48 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 01:46 pm: |
OK...now tell me.. what kind of amp/amps should i get to run 2 Shivas, 2 MTX subs and the MTX Trio.. I think i'm going to run a JBL BP 1200 for the 2 MTX subs and the MTX Trio but what should i use to run the shivas? something that would do the job and be cheap like in 100-200 dollas cheap mabey lil over |
Post Number: 232 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 01:59 pm: |
I only compete w/ my brother. You're nuts dude. You want to run the Good amp to the "so-so" subs and you want a cheap amp for the Shivas. Yes I said get the subs first, then the amps, but that doesn't mean to go and make a bad decision on the amps. Why the hell do you want that many subs anyway? Maybe it's just a maturity thing, but I try to keep my ride as quite as possible on the outside. First of all, can you tell me/us what model the MTX subs are? |
Post Number: 53 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 04:28 pm: |
OK mazda i didnt mean like a crappy amp for the shivas.. less u think i can only get a crappy one for round that price. but i want somethin that can push em good..According to you guyz it dont take much to push em thats why i didnt think of anything high for an amp with em.. |
Post Number: 242 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 08:36 pm: |
Okay, I might have went off a little bit, my sincere appologies. What model are the MTX subs so we can figure what they'll need to run if you even need them. You're looking to spend about $260 on the Amp for the Shivas (at least for the ones I would use) which would be the Kicker KX600.1, MTX 801d, XTANT A6001 |
Post Number: 70 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 08:40 pm: |
aight all thats good i'm lookin to running the....MTX Road Thunder RT10X3A 10 Tri-Sub Loaded Enclosure and 2 MTX Road Thunder RT12-44 12 DVC Subwoofer |
Post Number: 71 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 08:45 pm: |
Mazda would i be doing better or worse if i got a Phionex Gold Mono amp ? |
| Posted on Tuesday, September 21, 2004 - 08:59 pm: |
you can get the kicker Kx600.1 for $150 on google. good luck |
Post Number: 73 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 09:18 pm: |
thx Luther but i'm already lookin at the KX1200.1 or the MTX 1200.1 |
Post Number: 250 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 12:07 am: |
I don't know man.....I don't know. You can't run all that stuff off 1 amp yo. You just can't. |
Post Number: 78 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 12:28 am: |
i know u cant..If i could then i'd prolly do it.. but i think i'ma look at Sound Solutions to see what all they have in mind sell alot of Kicker there so we'll see |
Post Number: 257 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 12:38 am: |
Yeah, you can see what they suggest, and then buy it off the net cheaper! LOL. I think that's fun. See what these places suggest and then buy it cheaper MWUUUUUHAAAAHAAAHAAAHAAAHAAAAA. Damn I'd hate to be a salesmen.....wait, sometimes I am. |
Post Number: 81 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 12:41 am: |
lol yea..U ever herd ron white.. and the Car Salesman? remines me of me..lol....Yea then have them install it since i no absolutely NOTHING about it..lol |
Post Number: 262 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 12:49 am: |
LMAO |
Post Number: 89 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 01:02 am: |
The "yea then have them install it since i know absolutely NOTHING about it" is bout the buying speakers and amps off the net.. |
| Posted on Wednesday, September 22, 2004 - 01:04 am: |
dont you just love it when to guys at the audioshop dont have a clue about the stuff they sell! some of them at a shop near where i live just love sony, boss, and audiobahn.....hey think audiobahn puts JL to shame! also they no one round here even knows Adire, RE, DD, and MMats even exist! its like a few of my friends and me are the only people within 200 miles that these companies even exist!!! |
Post Number: 268 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 01:06 am: |
Then you've got one of the best kept secrets. You can put everyone else to shame. |
Post Number: 91 Registered: Sep-04
| Posted on Wednesday, September 22, 2004 - 01:08 am: |
Sounds like where i live.... |
