Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Is this right, Dual 4 ohms to make 1...
Author Thread: Is this right, Dual 4 ohms to make 1 load
is this the way to install a 600 jbl amp 2 Dual 4 ohm in parallel is 1, right? 2_4ohmDVC_1ohm.gif
Username: Fishy
Tamarac, FL
Post Number: 78
If you mean you have two dual 4 ohm voice coil subs with voices coils wired in parallel wired in parallel again, yes that will give you a 1 ohm load.
If you're talking about the BP600.1 then thats fine. That amp is 1 ohm stable. If you have the GTO601.1 don't doeeet!
-Fishy
the bp, what does this set up do for me?
the reason i ask is because I read it sends 300 watts to each sub, now I don't know how I have them set up but its not at 1 ohm, so am I still getting 300 per sub, i think not, right? so is this the best thing to do to get the best out of the jbl amp?
Username: Fishy
Tamarac, FL
Post Number: 93
Well if thats the speakers you have then thats the best. I'd rather see the amp run at a 2 ohm load, but if thats what you have, thats what will work best.
Exactly what subs do you have? DVC's confuse the hell out of a lot of people including me. Just wanna make sure we're on the same page.
-Fishy
infinity kappa's dvc, thanks...
Username: Joe718
Brooklyn, NY
Post Number: 122
well you just have to use a series/parallel wiring to get 2 dual 4 ohm subs down to 1 ohm. heres a link to a diagram that should help you. http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wi ring.html?subs=2&impedance=DVC4x2
Home > Message Board > Car Audio > Amplifiers > Archive through September 18, 2004 > Is this right, Dual 4 ohms to make 1... [ « Previous ] [ Next » ]
