15 Tips for Better Home Audio
| Posted by Admin on Saturday, August 01, 2009 - 07:25 pm: |
Sound quality is a major part of the home A/V experience, but it sometimes gets overlooked. We've come up with 15 ways to help you get better sound, many of which are free. Think of your audio system as a chain. The source, the audio component, the connecting cables, the amplifier, the speakers -- they all affect the sound you hear. But as you'll see from our list below, just making small, simple improvements to individual parts of that audio chain can make a big difference.
Get better sound with these completely free tweaks
Tip #1: Seek out good recordings -- the first link in the audio chain.
A well-engineered recording -- whether it's music or a movie soundtrack -- can make any system sound like a star. Most music- and movie-review websites tend to focus on the artistic aspects of recordings, but a few of our favorites also rate sound quality. Playback is a monthly online magazine featuring capsule reviews of the latest music discs. Both the print and web versions of Stereophile magazine feature an annual list of "Records to Die For" penned by the magazine's knowledgeable reviewers. And The Absolute Sound offers guides in a similar vein. Whether you like rock, jazz, classical, or all of the above, you'll find intriguing suggestions.Tip #2: Select a lower level of compression -- or better quality -- for your music files.
If you've got enough storage space on your iPod or computer, try selecting a higher "bitrate" setting in your music software, such as 256 Kbps (kilobits per second), when "ripping" tracks from your CDs. If you're downloading music tracks from an online store, check out the technical specs of the files more and more, you can find songs encoded at higher bitrates for little or no additional cost.
Higher-bitrate files are larger, but they also sound better. Programs like iTunes and Windows Media Player can also create "lossless" audio files, which maintain CD-quality sound while cutting the required storage space roughly in half. See our article about the MP3 format for more info.
Tip #3: Place your speakers carefully.
Your speakers are the "voice" of your system, and setting them up carefully can help you get the most out of your investment. Our article on positioning your speakers properly offers detailed placement instructions. But even after you've followed those suggestions, you may still be able to improve your setup with small adjustments. Have the member of your household with the most discerning ears sit in the main listening position, and check whether:
- the front speakers sound best facing directly into the room, or angled slightly inward toward the listener
- the center channel sounds better above or below the TV (assuming you have both options)
- your surround speakers are most effective when facing straight, or angled toward the main listening position.
Take a little extra time to set up your speakers properly, and your ears will thank you.
Tip #4: Dial in your subwoofer's settings.
Tip #5: Take advantage of your receiver's auto setup features.
Tip #6: Use your receiver or disc player's "Pure" mode for better sound.
Sending music signals through unnecessary circuitry can add unwanted noise and distortion to your favorite recordings. That's why some receivers and disc players offer a "Pure" or "Direct" mode for playing music. These modes give you the option of switching off unused or unneeded portions of your component's circuitry to provide the cleanest possible signal path, and minimize potential electronic interference. If any of your components provide these types of options, give them a try. You might find that the resulting sound is clearer and more detailed.
These upgrades give you great bang for your buck
Tip #7: Don't settle for your TV's built-in speakers.
TV cabinets have gotten thinner and thinner, leaving less and less room for built-in speakers. The result? Flat, muddy sound that just doesn't do justice to today's high-def displays. You've got a lot of options for improving your TV's sound -- from popular single-speaker sound bars to full surround sound systems, and everything in between. Many of these options are compact and simple to set up. See our article on four ways to improve your TV's sound for more info.
Tip #8: Take advantage of the latest surround sound formats from your Blu-ray player.
- If you have a Blu-ray player with built-in decoding for Dolby TrueHD or DTS-HD Master Audio, you can connect it to your home theater receiver via HDMI or multichannel analog audio cables.
- If your Blu-ray player doesn't have the necessary built-in decoding, you can pass the signal via HDMI to a receiver that can decode those formats.
Tip #9: Try better speaker wire -- a logical first step in upgrading your audio connections.
Tip #10: Biamp your speakers.
If you've purchased a home theater receiver in the last couple of years, it may have extra channels of amplifier power that you can put to use for better sound. That's because most newer receivers have seven amplifier channels, while many people only use five speakers in their home theater setup.
If your receiver's "surround back" channels are going unused, check if you can redirect the power to <span>biamp</span> your front left and right speakers. This neat trick gives you four dedicated amplifier channels to drive your front two speakers, essentially doubling the available power for more dynamic, higher-quality sound. Check out Dave's post on biamping your speakers for more info.
Note: Your receiver must be able to redirect unused amp channels, and your front speakers must each have two pairs of input terminals (also known as "biamp inputs") as shown below.
Dual sets of binding posts permit biamping or biwiring. These speakers come with jumpers that connect the two sets of binding posts for regular use (left photo). For biamping or biwiring, simply remove the jumpers (right photo).
Tip #11: Bypass your iPod's built-in digital-to-analog converter.
Tip #12: Use a power conditioner -- protect your gear and improve its performance
Higher-end options for really great sound
Tip #13: Use high-quality source components.
High-quality source components typically offer sturdier construction, costlier precision-built parts, and larger power supplies to help bring out subtle nuances in your music that you may not have heard before. Most listeners experience deeper, better-defined bass, smoother highs with more detail, and a greater sense of space and realism.
Some of our favorite high-quality source components are Marantz's SA8003 SACD/CD player and TT-15S1 turntable.
Tip #14: Try a smokin' outboard DAC -- get shockingly good sound from your CD collection.
Tip #15: Upgrade to high-performance loudspeakers.
- Learn more about choosing speakers.
- Read a review of the Polk LSi9 bookshelf speaker.
- Read a review of the THIEL SCS4 bookshelf speaker.
- Read a review of the THIEL CS3.7 floorstanding speaker.
