Home > Message Board > Articles > Archive through September 19, 2006 > Personalize your ringtone
Want to get away from those boring ringtones that come as standard? Feel the urge to stand out and identify your phone ringing in a crowd? As people, especially those fashion-minded youngsters, are eagerly in pursuit of something personality-defining, a tide of ¡®DIY all the things¡¯ has become ever more higher. Well, the passion to ¡®escape the mundane¡¯ is by no means a demonstration of obsessive self-worship, but an incentive to polish your imagination and creativity, and add an air of individuality to your cell! Create your own ringtones out of any material you can get, your own voice, musical performance, family audio files, or any other recorded wild sound. Let those personalized sound lead you towards achieving your own lifestyle goals because the music you listen does say a lot about you to those around you.
To make this fantastic idea come true, all you need is some compact and powerful software. There is no doubt that those tech-savvy and profit-sensitive guys will grab any opportunity to share this luring cake, thus existing so many audio managers, helping you click out amazing sound for your mobiles. There are several worthy of recommendation, Mobile Ringtone Converter, AVS Ringtone Maker ,etc.
Mobile Ringtone Converter can convert / record / mix audio to Moblie Ringtone as MP3, OGG, AMR, MMF ,AMRWB, WAV fast and easily and enables you to make your own ringtone.This soft supports many features, just to list some.
Can set convert quality, sample rate, bitrate;
Can convert by selected part;Can mix multiple tracks;
Can edit Wavform;
Can set ringtone quality, such as mp3 birtrate, ogg quality, AMR mode;
There is a detailed guide and a link for free trial version download on this site: http://www.sharewareguide.net/article/Guide/guide:-how-to--make-your-own-rington e-with-the-ringtone-maker-software.html
AVS Ringtone Maker can create custom ringtones from any input audio of the following formats: MP3, WAV, AMR. It also has its own shining points.
Can take any audio file as input, trim it, cut out the needed part, delete the unnecessary parts;
Can record any input sound to make it a ringtone;
Can mix several audio files to be a ringtone;
Can apply effects to the mixed audio sequence;
There is further info on this site:
http://www.avsmedia.com/AudioTools/ringtone-maker.aspx
There are many other such tools out there, not to elaborate on more here. You can d/l several trial version to compare their performance and check which meets your demands more before you clinch the worthy pay.
[ « Previous Article ]
[ Next Article » ]
