Make your iPod more friendly
| Posted by kevintsa on Thursday, July 20, 2006 - 11:06 pm: |
I once also stumbled on the same problem, and with a spirit of trial and error, I googled for some possible software to do this work.. I came to pick up several gadgets, and after some comparison work, I found the superior one Imtoo iPod Moive Converter. It is a comprehensive gear featuring many functions and a user-friendly interface, which to newbies like me, is of great convenience. Just a few clicks and created the envisioned format file.
The iPod Converter offers a powerful way to convert all popular video files such as AVI, MPEG, WMV, MOV, MP4, RM, RMVB, H.264, VOB, DivX to iPod movies. It helps you watch music video and movies on your video iPod with ease. In addition, the iPod video converter can also extracting audio from movies or music video and convert it to iPod supported MP3, AAC, M4A format!That is to say ,you can enjoy soundtracks your favorite movies, e.g. that of Brave Heart?
Here is the interface of this software:
[img]http://www.imtoo.com/ipod-movie-converter/ipod-movie-converter-screen.html[/img]
You can see that many settings are provided to customize your demands.
And its key features it include, among many others,are:
Multi-threading and batch conversion supported, thus the more files you convert the faster ImTOO iPod Movie Converter works than other iPod converters ;
Easy to use as all properties and settings are displayed in the interface which are easily handled , all encoders/codec are built-in for you to finish the supported conversion directly ;
Auto-selects another proper codec for you once any problem occurs during the conversion ;
Preview is supported and you can preview the input files before conversion ;any clip or segment can be converted by ImTOO iPod Movie Converter ;
Output files can be renamed and the output path can be easily modified
To those who are right now pinching pennies, the low price of $29 is very appealing. So there is every reason to download the trial version and check it before you decide to pay for this magical softwareļ If you have any problems during the conversion, you can put up your confusions, and we can have a discussionļ
[ « Previous Article ]
[ Next Article » ]
