Home > Message Board > Articles > How can i convert gvi video files to avi video files?
Naevius GVI Converter is the program that allows you to convert Google Video Files (GVI) to AVI format.
Add GVI files, click Start button and You will get AVI files.
Useful, easy and conveniently!
How work it?
1. Run Naevius GVI Converter.
2. Select Output Folder ("D:\" for example).
3. Click "Add..." button and add GVI-file ("C:\video\test.gvi" for example).
4. Click "Start" button.
5. As result will be file in output folder ("D:\test.avi" for
example).
Screenshot:
http://naevius.com/files/gvi_converter.jpg
Download:
http://naevius.com/files/gvi_converter.exe
[ « Previous Article ]
[ Next Article » ]
