Home >
Message Board >
Articles >
Archive through September 19, 2006 >
How to convert RM to AVI/ DivX/ Xvid/ MPEG1/ MPEG2/ VCD/ SVCD/ DVD(*.VOB) ?...
| Posted by swg on Tuesday, May 09, 2006 - 03:53 am: |
Introduction of this RM file converter
This RM video converter can help you convert RealMedia(*.RM,*.RMVB) files to AVI, DivX, Xvid, MPEG1, MPEG2, VCD, SVCD, DVD(*.VOB) files.
With the fast and powerful RM/RMVB decoder inside, Ultra RM Converter can support almost all RM/RMVB files, even RealPlayer has not been installed.
The main features include:
Batch convert RM, RMVB files to various format files;
NTSC/PAL setting options for DVD, VCD, SVCD exporting;
Change the video bitrate, audio bitrate, framerate, image size etc as you like;
Very user-friendly interface and easy to use;
Very quick in conversion speed and no quality is lost!
Key Features:
Powerful RM file converter;
Convert RM to DVD and RM to VCD;
Convert RMVB to AVI and RMVB to MPEG;
Supports RM, RMVB formats to AVI, DivX, Xvid;
Supports RM, RMVB formats to MPEG1, MPEG2;
Supports RM, RMVB formats to VCD,SVCD,DVD(PAL,NTSC);
With the fast and powerful RM/RMVB decoder inside, supports almost all RM/RMVB files. Do not need install RealPlayer;
Multi-task batch execute function;
Support large video file, even large then 2GB Very fast and without any quality loss;
Very User-friendly interface.
Step-by-step Guide: (Take converting RM to AVI for example)
Step 1: Free download this RM file converter from http://www.sharewareguide.net/downloadit.php?pd_id=3656 and run it.
Step 2: Launch this RM file converter.
Step 3: Click "Add Files" button to select RM file as input file.
Step 4: Click "Change" button to select a path for the AVI outputed file, Or you can don't take any operation and use the default path.
Step 5: Click "Output Format" combo-box to select AVI as the outputed file.
Step 6: Click "Convert" button to start to convert RM to AVI:
OK. You successfully compelete to convert RM file to AVI with this RM file converter. And you can use the same steps to convert RM to AVI/ DivX/ Xvid/ MPEG1/ MPEG2/ VCD/ VCD/ DVD(*.VOB) format with this RM file converter.
Do you ever want to convert RM to DVD and RM to VCD? Do you want to convert RMVB to AVI and RMVB to MPEG? Why not use this RM file converter
[ « Previous Article ]
[ Next Article » ]
