Home > Message Board > Articles > Archive through December 30, 2005 > The TiVo 30-Second Commercial Skip Hack
| Create New Article | Reply | Edit
Hack #96 from Home Theater Hacks by Brett McLaughlin (O'Reilly Media).
Forget about fast forwarding through commercials; blaze through in just three to five clicks of your remote.
One of the religious differences between TiVo and ReplayTV owners is how they fast forward through commercials. While TiVo's Upload button will get you through those intrusive breaks soon enough, it requires some trained skill to manipulate those Upload and Upload buttons while keeping a keen eye and trusting your instincts to anticipate the end of the commercials. ReplayTV, on the other hand, has a "30-second skip" button, timed specifically for skipping through commercials. Since television commercials are traditionally a multiple of 30 seconds long, ReplayTV owners just hit the "30-second skip" button three to five times to render commercials only a minor annoyance.
This feature is so effective that it has stirred up quite a bit of controversy with the networks, who are getting their hackles up, labeling commercial skipping as theft and even taking ReplayTV to court.
Don't you wish TiVo had a 30-second skip? It does, thanks to a little Easter egg magic.
The Upload button on the TiVo remote will bring you to the end of a program, or if you are at the end, it will bring you to the beginning. If you are fast forwarding, the Upload button will skip you to the next tick mark. This hack is all about repurposing that button to act as the 30-second skip.
Bring up any recorded program or Live TV. Then, enter the following sequence on your remote:
Select ® Upload ® Select ® 3 ® 0 ® Select
You'll know the combination worked when TiVo rings out three Thumbs Up sounds; that chiming "bling!" sound TiVo makes when you press the Upload button on your remote control. Your Upload button will now skip forward by 30 seconds.
Note that this hack isn't permanent. If at any time your TiVo needs to be rebooted -- after becoming unplugged or as a result of a power failure -- the hack will go away and you will have to reapply it.
coverThis material has been adapted from Home Theater Hacks by Brett McLaughlin, published by O'Reilly Media, Inc. Copyright O'Reilly Media, Inc., 2005. All rights reserved.
A smart collection of insider tips and tricks, Home Theater Hacks covers home theater installation from start to finish, purchase to experience. Just imagine: no frustrating trial and error process and better yet, no expensive appointments with installation experts. Home Theater Hacks prevents both by imparting down-and-dirty technique not found anywhere else.
Home Theater Hacks is available for purchase from Amazon.com, Amazon.co.uk, Amazon.ca and the sellers listed below.
Author Comments
Demani
Is this possible on the combo Tivos (like my Toshiba SD-H400)? What button is the (R) ?
TiVoguy
Just worked on my DIRECTV Series 2 TiVo running 6.1 software. That Toshiba remote is weird, but I bet it still works. The (R) is just junk. I don't know why it's showing up. Ignore it.
HypeNotHack
This hack is not enabled on all Tivo models. The Toshiba SD-H400 is an example of a unit that cannot implement the 30 second skip. Additionally, with Tivo's rollout of the new ad banners 30 second skip will be disabled on all units with a imminent firmware upgrade.
Home > Message Board > Articles > Archive through December 30, 2005 > The TiVo 30-Second Commercial Skip Hack [ « Previous ] [ Next » ]
