Component Video Cables -- A Guide
Component video cable, in just a few years, has gone from being a relatively uncommon and esoteric way to hook up video devices to being the near-universal analog video signal standard for home theater and high-definition television. Where a few years ago s-video and composite were the most common and widely usable video signal standards, component video has emerged as the leader because it is the only common consumer analog signal type which supports progressive scan and high-definition resolutions, and because it is the standard output format of DVD players. Component video cables, then, are needed in almost every home theater setup. Naturally, people want to know: what makes the best component video cable? Why are there so many component video cable types on the market? How can I choose the component video cable that will do the best job in my system? To help address these questions, we've put together this little treatise on component video, and component video cables. What is Component Video? Before we get to the subject of what a component video cable is, let's talk about what component video is. All conventional methods of sending an analog video signal from one device to another involve a few basic types of information. These types are the scan information (e.g., when does a line of video start and end, and when does a frame start or end?), the brightness information (how bright should this part of the image be?) and the color information (what color should this part of the image be?). Composite video, s-video, component video, and the various types of RGB video all constitute different methods, or formats, for delivering this information. At one extreme is composite video; all of the information, from the sync pulses used to deliver scan information to the luminance (brightness) and chrominance (color) portions of the signal are all delivered as one unified, "composite" signal, traveling down one wire. At another extreme is RGBHV; instead of one wire, there are five, carrying horizontal sync, vertical sync, and the brightness of each of the color components, red, green, and blue. Component video is akin to RGBHV, in that its color information is broken out into pieces to keep red, green and blue separate. However, instead of delivering red, green and blue as such, component video is what is known as a "color-difference" signal. To reduce the number of connections from five to three, the horizontal and vertical sync signals are combined with one of these signals, so that we have three connections. The "green" connection, rather than carrying green as such, is the Y, or "luminance," channel, and in addition to carrying a signal for the total brightness value, it carries the sync pulses. The "red" channel, Pr, instead of carrying the red value, carries a difference signal: R-Y, or red minus total luminance, usually referred to as "Pr." The "blue" channel, likewise, carries B-R, blue minus luminance, or "Pb." The display interprets the Y, Pb and Pr components of the signal and derives the values of red, green and blue from them. This, combined with the scan information, allows the display to render the intended picture. Component video is a multiscan format, which is to say that it may be delivered, unlike composite or s-video, in however many lines and at whatever frame rate one wishes, in either interlaced or progressive scan modes. This is why, when you're hooking a DVD player up to a display, progressive scan mode is ordinarily only available through the component video output; and this is also why, when dealing with a device like an HD TiVo, one can only get the high-definition analog output when using a component video cable connection. What is Component Video Cable? For many years, the standard method of hooking analog video devices to one another has been through 75 ohm video coaxial cable. Long before these cables were in common use in the home, broadcast and production houses were wired with 75 ohm video cable, generally running composite video. The advantages of 75 ohm video coax include excellent impedance tolerance (good for preventing signal reflection, which causes ringing and ghosting), excellent shield performance (important in a high-noise environment like a TV studio), and low loss (good when one needs to run video over long distances without significant degradation). Not too surprisingly, when component and RGB video came into common use, the same type of cable was used to hook them up--the difference being, of course, that when there are three signals, as in a Y/Pb/Pr component video cable run, one needs three cables to run them in. So, whether they're joined together in a sheath, bonded together in a ribbon configuration, or just run separately, component video cables always consist of three cables which are electrically separate. Each member of the set of three is its own, separate 75 ohm video coaxial cable, with its own center conductor and shield. But what does it mean to say that a cable is "75 ohm," or "coaxial"? Well, a "coaxial" cable, or "coax," is simply a cable in which all of the elements share a common physical axis. What this means is that the elements of the cable are cylindrical (at least, when the cable is not bent), and are laid around one another, so that the axis around which the jacket, shield, and dielectric (the insulating layer between the center conductor and shield) are constructed is the same as the axis of the center conductor. If you cut a piece of coaxial cable, the cross-section looks like the drawing at right. When we say that a video cable is "75 ohm" cable, this is a reference to the cable's "characteristic impedance." Characteristic impedance is a bit difficult to understand; although it's expressed in ohms, like resistance, if you take a volt-ohmmeter to a video cable, you won't find 75 ohms of resistance anywhere. Characteristic impedance has to do with whether the cable is electrically matched to the input and output circuits of video devices, which are all designed to accept or emit signals at 75 ohm impedance (meaning, to over-simplify for a moment, that for every volt of signal presented, current will flow through the circuit at the rate of 1/75 ampere). When device inputs and outputs are not impedance-matched, portions of the signal can be reflected back and forth through the connection between them; in a severe case, this will manifest itself as ghosting, or "ringing," of the image. When a cable is badly-matched to the input and output impedances, the output device, in a manner of speaking, "sees" a load of the wrong impedance, and the input device does likewise, causing these reflections. Component Video Cable Connectors All good things, as they say, must come to an end, and that's true of video cables as well. Instead of terminating video cables directly into our television sets, projectors, DVD players, and the like, we use connectors to make those junctions. The quality of these connectors can be an issue with component video cables, and is worth a look. First, it's important to point out that there is no such thing as a "component video connector." Component video can be run through any of a variety of connector types, and it's still component video. RCA, BNC and other connectors are commonly used, and these connector types can be used for other types of video as well, so it's a good idea not to mix connector types and signal types when speaking of component video cables. We're often asked whether, for example, we can make a component video cable that "goes from component to BNC," and the answer to that question depends on just what's meant. If the question is whether we can build a component video cable with BNC connectors on one end, the answer is yes; if the question is whether we can run component video into a BNC composite, RGBHV or Y/C connection, the answer is no (at least, not without a converter box of some sort).
The most common form of connector for component video cables is the RCA connector. This connector was, of course, named for the familiar RCA company, Radio Corporation of America, and is often referred to as a "phono" connector because its original application was to allow the audio output of a phonograph to be fed into a radio or other amplifier. RCA jacks (the "female" RCA connector) are familiar to anyone acquainted with consumer electronic equipment as the standard plug-in points for audio of all sorts and, nowadays, for most composite and component video; at right is a photo of a set of RCA jacks meant to accept a conventional component video cable.
Most professional gear, and some high-end consumer gear, uses another type of connector: the BNC, a bayonet-style connector. A BNC jack (see photo at left) looks quite different from an RCA jack--it sticks more prominently out of the equipment panel, has a smaller pin socket (which looks not unlike a pin itself, until one realizes that the "pin" is hollow), and has two nubs on the outside of its outer contact to accept the turning bayonet ring on the male connector. Component video is sometimes run through a VGA, or "HD15" type connector, which has fifteen pins, arranged in three rows of five; this is done most often on projectors, probably to save space, and is a source of potential confusion because the standard VGA signal format, which many projectors also accept, is not component video but RGBHV. One cannot always assume that a device with an HD15 input will accept component video; computer monitors almost never will, data projectors sometimes will, and home theater projectors almost always will. If component is accepted, the signals go in to pins 1 (Pr), 2 (Y), and 3 (Pb), with the grounds going to pins 6, 7 and 8, respectively; this, fortunately, corresponds to the pinout for red, green and blue in a conventional VGA/RGBHV signal, so we can use the same adapters and cables with component that we use with those signal types. The HD15 is a nasty little connector, not really well-adapted to this sort of use, and poorly sized from the point of view of video cable--but when you've got to use one, of course, none of that matters much. Obviously, for each type of connector on an equipment panel, there's a corresponding male connector that plugs into it. The vast majority of consumer equipment uses RCA inputs and outputs, so the vast majority of component video cables are built with RCA plugs to go into those jacks. The RCA plug and jack, having been designed for analog audio, were not designed to match a 75 ohm characteristic impedance, and their dimensions are such that they can't be matched to 75 ohms. What one can do, however, is make the length of the mismatch as short as possible, which minimizes the impact of the mismatch. Canare crimp RCA plugs do this by carrying the coaxial structure and dimensions of the cable forward into the plug body as far as possible; generally speaking, solder-type RCA plugs are inferior from an impedance match standpoint because the need to provide contact for soldering and allow space to screw on the connector shell do not allow the 75 ohm impedance to be carried as close to the tip as in the Canare design. There are a few other crimp plug designs on the market which are akin to Canare's--ADC, for example--but most manufacturers of component video cables use solder connections. Apart from impedance match, the most important characteristics of an RCA plug for use in a component video cable are its mechanical stability--that is, how well it will hold up to usage--and its facility for making good electrical contact with equipment jacks. Plating with a non-corroding metal, such as gold or nickel, helps prevent oxidation from compromising the quality of the contact, and the ideal plug should grip the jack firmly without being so tight as to damage it. Here again, we're partial to the Canare plugs, which use a set of spring contacts to grip the jack but which can be removed easily enough with a firm tug; we have occasionally had customers report that the plugs on some of the common consumer cable brands are so tight that, when a cable was unplugged, the plug pulled the jack right off the back panel of the device. That certainly makes the point that sheer mechanical grip strength, without a mechanism that enables easy removal, isn't necessarily a good thing. Component Video Cable Quality So, what makes a high-quality component video cable? It really boils down to a few technical considerations; we'll go through those, and meanwhile touch on a few issues which don't really matter as much as is commonly believed. Size is Overrated Over normal run lengths and with cable of reasonable parameters, the amount of signal lost to resistance in the cable is not particularly significant; this is especially so because, even to the extent that resistance causes loss, the loss is linear--it affects all frequencies in the signal equally, and so when the display receives the signal and adjusts its amplitude (usually done by reference to the strength of the sync pulses), all of the information is still present regardless of the loss of signal strength. Over reasonable run lengths (say, under 100 feet), these losses are not really significant so long as one is dealing with a cable having a reasonably-sized center conductor (say, 22 AWG or larger). So, What Really Matters? But there are technical deficiencies a component video cable can have, which can have dramatic impact upon signal quality, especially where runs are sufficiently long to make the impedance of the cable a significant consideration. With full-blown HD component running at about 35 MHz, the wavelength of the signal, corrected for the speed of propagation in a high-quality coaxial cable, is about 24 feet, making even a six-foot component video cable a significant fraction of the wavelength and potentially a factor in signal quality. What's All This About Impedance? Here, one might ask: isn't it sufficient to make sure that the video cable is 75 ohms? After all, that's the impedance required to match all common video gear, and if one uses 75 ohm cable, there's nothing else to think about where impedance is concerned...and that would be true, if we lived in a perfect world where cables always met their design objectives perfectly. In practice, cable is seldom exactly 75 ohms. Small variations in the shape and diameter of the wire used in the center conductor, the consistency of the dielectric, the centering of the wire within the dielectric, the size and tightness of the shield around the dielectric, and the behavior of the cable when flexed, make it impossible to build cable precisely and always at 75 ohms. For that reason, any manufacturer of video cable is always working to produce cable within an acceptable range around 75 ohms. A manufacturer specifies how close the cable is guaranteed to be to 75 ohms in a spec called "impedance tolerance," expressed as a +/- range. Without a published specification for impedance tolerance, there's no way to know whether that "75 ohm" cable is 75 ohms plus or minus 1.5 ohms, or 5 ohms, or 15 ohms. This tolerance is the single most important technical spec to look to in determining video cable quality, especially at long lengths; the best video cables available today, "precision" video cables designed for serial digital video transmission, control impedance to a published spec of +/- 1.5 ohms, and, as a practical matter, rarely wander off more than about .5 ohm. This is where cable size tends to come into the matter, at least indirectly. Since all of the dimensions which determine impedance have to be controlled in the manufacturing process, naturally, it's easier to control impedance tightly if the dimensions are not tiny. No cable with a 30 AWG center conductor can be built to the same impedance tolerance as the best cable with an 18 AWG center conductor. It's simply easier to control the fineness of construction of a larger cable than it is when working with a smaller cable. For this reason, we recommend that if you need to make a long-distance connection which will terminate in an HD15 ("VGA") type plug, you use a short "breakout" adapter to allow the use of full-sized cable for the main run, rather than making the whole run in miniature cable suitable for soldering to those tiny VGA pins. We're often asked whether using an adapter will introduce too much "loss" into the line; the answer is that the adapter is there to prevent loss, both from attenuation and from poor impedance tolerance, by allowing the main run to be made in larger, lower-loss cable. Shield Effectiveness Another significant factor in component video cable quality is shield effectiveness. Any video connection is potentially subject to electrical noise which enters from a variety of sources; these range from low-frequency hum (60-cycle noise from power circuits, transformers, fluorescent lights, etc.) all the way up to radio-frequency interference (from television and radio stations, computers, etc.). Video quality can be compromised by noise from these sources; how much this is so will depend heavily upon the amount and type of noise in the environment. The composition of the shield in a component video cable will determine how effective it is at preventing interference; the best shields for broad-frequency coverage, all the way from low-frequency hum to RFI, are combination shields consisting of both a heavy braid (wire woven around the dielectric in a sort of mesh) and a full-coverage foil (usually aluminum, wrapped around the dielectric). The most common way to save a bit of money on cable construction here is in the braid; lower-quality coaxial cables will sometimes use an aluminum braid (significantly less conductive, and consequently less effective, than copper), with poor coverage--as low as 60%. Generally, one should look for a copper braid, with 95% coverage (100%, while it'd be nice, isn't possible because the nature of wire braid is that it has holes caused by the way it's woven), coupled either with a full-coverage layer of foil or with another heavy braid. Timing is Good, But... "Timing" is a consideration in component video cable quality, and while it's meaningful, it's often over-emphasized. The three cables in a component video cable should all be of the same electrical length--which is to say, it should take a signal the same time to travel through each of them as it does to travel through the others. The speed at which a signal travels through a cable depends on two things: the physical length of the cable, and the consistency of the dielectric material. If the manufacture of the dielectric is highly consistent, and the cables are cut to equal length, then timing variation between cables will be insignificant. This requirement for a consistent dielectric, as it happens, is directly tied to "impedance tolerance," of which we spoke above. The impedance tolerance reflects the consistency of the dielectric, and so the tighter the tolerance, the lower the potential for timing error. But timing, as we've suggested, is often a bit over-sold. The broadcast-quality benchmark standard is that timing should be within 40 nanoseconds (abbreviated "ns") from one channel (that is, one cable in the set of three in a component video cable) to another. Using a cable having a tight impedance tolerance of +/- 1.5 ohms, or +/- 3 ohms, it's impossible to get more than a few nanoseconds per hundred feet of timing variance from one cable to another, if those cables are cut to the same physical length. Cutting them to different lengths, of course, would do the trick--but it takes a large discrepancy in cable lengths to make up a 40 ns difference. Consider, for example, Belden 1694A. Electricity travels down the center conductor at 82% of the speed of light (this is what's called the "velocity of propagation" of the cable), and so takes 1.24 nanoseconds to travel one foot. To cause a 40 ns delay by cutting 1694A cables to different lengths, one would have to make one of the cables about 32 feet longer than the others--and the resulting component video cable would still, albeit just barely, be within the broadcast quality standard. Center Conductor Material: Not the Critical Issue it's Often Thought to be The universal choice of conductor material in professional video cables, used in the production and broadcast industries, is copper. One will sometimes see silver touted as being superior, on the basis that silver is slightly (about 5%) more conductive than copper. However, as we've pointed out, there's really very little loss to resistance (resistance is just another way--the inverse way--to express conductivity) in reasonable runs of component video cable, and what really undermines the claim, in any event, is that the slightly higher conductivity of silver is usually mitigated and offset by two factors: first, the silver in a silver cable assembly is usually a microscopically thin plating over a standard copper conductor, and second, the gauge of the wire is generally small; some popular silver component video cables use a 30 AWG center conductor--resulting in resistance about seven as high (or, if you prefer, conductivity about seven times lower) as in an 18 AWG plain copper center conductor. If the object of using silver is to promote conductivity, the choice of tiny wire to do the job is at cross-purposes with that object. Putting it all Together and Plugging it in In sum, the things that make an excellent component video cable are simply a matter of having a well-engineered product with tight tolerances and good design. A cable with tight impedance tolerance, effective shielding, adequately-sized for the run and terminated with mechanically solid connectors that make good contact with the equipment jacks and don't do too much to alter the impedance of the whole assembly will outperform anything else on the market. Exotic materials, novel-looking connectors, and fancy write-ups come and go; ask for a spec sheet when you shop, and demand details like impedance tolerance, shield braid coverage, and attenuation charts. If the claim is made that so-and-so's component video cables exceed the performance of the best broadcast-industry cable, then find out what the basis of that claim is. The manufacturer knows what his specs are; if he won't publish them, there's a reason. by Blue Jeans Cable (reprinted with permission) |
Author
Comments
Unregistered guest |
| Posted on Monday, February 21, 2005 - 05:34 pm: |
Your article was very informative. Thank you for publishing info like that. I had a question regarding lines of resolution. Can component cable carry 1080 lines of resolution? Overall do you know the max capacity for all formats(composite, s-video, component, DVI) Thanks. |
Video-new-be Unregistered guest |
| Posted on Monday, February 21, 2005 - 10:46 pm: |
Are there a couple of brand names that are readily available that match your recommendations? |
hope_Im_OK Unregistered guest |
| Posted on Tuesday, February 22, 2005 - 10:28 pm: |
Thank you for the interesting article. I am running a componet video line from my A/V equipment cabnet to the Plasma on the wall. The run is 25 ft. which I bought a VERY EXPENSIVE Monster Cable for. What worries me is the multiple connections. Device to RCA wall jack 1M, Monster cable 26 FT. to Smarthome wall component module. 1 ft. component from Smarthome wall to TV. Even though all the connections are gold plated should I worry about signal loss??? Thanks, |
stevebb Unregistered guest |
| Posted on Monday, March 14, 2005 - 03:37 pm: |
Interesting article...but should point out that component video is not just a DVD thing, but existed for many years as a standard in television stations. It's only in recent years that home consumer video products have adopted it. |
New member Username: Inti
Post Number: 2 Registered: Mar-05
| Posted on Thursday, March 17, 2005 - 10:23 pm: |
Yeah, that was good except I feel like you left me hanging. WTF? Can you give us a breakdown of cables that fall into various categories such as; Expensive Moderate Budget It appears that quality is has a very small delta between cables. Given your very good review about the technology, how about a bone for the products vs their cost? |
| Posted on Saturday, March 26, 2005 - 04:14 pm: |
I have a question and a comment. The question is: Can I use a 3-wire component video cable in place of a 3-wire audio/video (composite) cable? In otherwords, I would be upgrading, I think. The reason I ask is I already have a good quality 15' component cable, but I don't have an A/V cable. My comment is that you might be, at least technically, incorrect when you say the loss in a cable is linear and it affects all frequencies in the signal equally. Actually, attentuation in a transmission line is highly dependent on frequency. With RG-59, for example, attenuation is about 0.3 dB per hundred feet at 1 Mhz. At 700 Mhz, on the other hand, attenuation is about 10 dB per hundred feet. You might actually, be correct in practice, though. I don't know. If all the frequencies traveling on the 3 cables are approximately the same it probably wouldn't make any difference. Similarly, if the cables are very short, for instance, 6 feet, it probably wouldn't make any difference. |
| Posted on Saturday, March 26, 2005 - 04:59 pm: |
In regard to "hope_Im_OK", my humble opinion is as follows: First of all, it's not likely that you will have to worry about signal loss if the cable is large and I don't think that connectors would contribute directly to signal loss (attenuation). There is a theoretical problem with using multiple connectors, although, I tend to doubt if there would be a problem in practice. The theoretical problem is that the connectors might not actually have a true characteristic impedance of 75-ohms which could cause an impedance mismatch. As I recall, there's a rule of thumb that states that you don't have to worry about mismatches with devices that are less than 1/4 wavelength. To be safe, let's say 1/8 wavelength. Actually, to be safer, let's say 1/16 wavelength. Now, for the sake of argument let's assume the highest frequency in the cable is 200 Mhz (my guess is that it's no where near that). 200 Mhz converts to a wavelength of 200 centimers or about 60 inches. One-sixteenth of that would be 3.75 inches. My guess is that your TV and A/V equipment and cable have impedance matched connectors so the only ones that you would have to worry about would be the wall jacks and they would probably be fine even if they are not perfectly matched. |
| Posted on Monday, April 04, 2005 - 05:10 pm: |
I have a monster 3 Cable (Video (Composite), Audio (L and R)), Can I use it as Comopnent video cable? |
| Posted on Saturday, April 23, 2005 - 07:18 pm: |
Does any one the know the correct pinouts for a rgb 15 pin to rca-3 component connectors. I'm using this with Toshiba TDP-S20 projector. |
Alesmith_ Unregistered guest |
| Posted on Sunday, May 01, 2005 - 10:59 pm: |
Max, Yes, you can certainly use a new, high-quality digital/component cable in place of an older anaolg/AV cable. But, you shouldn't do the other way around. For those looking for specific cables, the Belden 1694A digital-grade coax cable is sort of the new standard for high quality cable. BlueJeansCable sells alot of it, reasonably priced ($12-$15 per length, so $36-$45 for a great 1m-2m component video cable). They terminate with high quality Canare ends. -Dave |
| Posted on Saturday, June 18, 2005 - 08:51 pm: |
I tried to connect a DVD with the TV with a Component Video Cable, however when I hook up the cable and turn on the DVD(Toshiba), the DVD goes into a "protection" mode and doesn´t work anymore until I wait a few hours. What could be happening ? |
Captain Munt Unregistered guest |
| Posted on Wednesday, June 22, 2005 - 11:20 pm: |
check your ship for leaks, as it is clear that you are runing the DVD player underwater. |
| Posted on Saturday, September 10, 2005 - 07:31 pm: |
Alesmith/Dave You say not to use an AV cable in place of a digital/component cable. Why? What is physically different between the two? Assume that they both have Canare ends. I am looking at an AV cable and a compoonent video cable side by side, made by the same manufacturer, and though I have not taken them both apart, they look identical (with the exception of the color coding scheme). |
New member Username: Rtama
Post Number: 1 Registered: Nov-05
| Posted on Monday, November 07, 2005 - 01:03 pm: |
I'm totally new to this. Attempting to run component video cable from Sony DVD to Plasma TV. Set TV for input from component jacks selected but get no video at all. When test on other TV just get bars of color but no picture. DVD is set to Progressive. |
New member Username: Jono63
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 29, 2005 - 04:53 am: |
i have a new dvd recorder (LG) and the quality of the picture with normal RCA cables is pretty dodgy, though i know my tv is capable of HDTV as its brand new, and has foxtel digital connected which works perfectly, so my question is, would buying the component cable and/or the S-video cable increase the picture quality i will be seeing on my screen?? any news wil be helpful as i plan to go and purchase some cables tomorrow thanx heaps,you can reach me at jonol63@gmail.com Jono |
New member Username: Barrengonads
Cummings,
Iowa
Post Number: 1 Registered: Jan-06
| Posted on Thursday, January 12, 2006 - 01:57 pm: |
While pulling component wire through a pvc pipe, the connector of one of the cables broke off the wire...They are 10M of cable, and I was wondering if I can splice...Cut an end off another cable and spice the wires together. |
New member Username: Chriswilson
PA
United States
Post Number: 1 Registered: Mar-06
| Posted on Monday, March 06, 2006 - 09:53 pm: |
After 2 months of use, my DVD-VHS player's colors are bad. Everything has blue cast - faces, things that should be red (car brake lights) are blue. Do you think something in my player went or could it possibly be the cables? Any info would be welcomed. Thanks. Chris wilsonhardware@juno.com |
New member Username: Lewisbecker
Post Number: 1 Registered: Sep-06
| Posted on Friday, September 08, 2006 - 07:10 pm: |
Ive been reading up on all things component. About two months ago I heard that the Belden 7710a Component Cable is regarded as a " hell of a cable " for the price. I ordered one two weeks ago and can only say WOW. The size of the thing. I mean it looks like some hard core industrial underground cable. Anyway ive seen a vast inprovement on my system. Only slight downside is the cable is really thick, so if your needing to have a lot of flexablity it might prove to have some problems in certain applications. Lewis |
New member Username: Johnstanley
Post Number: 1 Registered: Feb-06
| Posted on Sunday, March 11, 2007 - 11:43 am: |
I have Yamaha amp with two component input and I output which goes to TV. My TV only has one component input. Unfortunately I have a DVD Player, A cable provider Box and HD PVR. Is there a splitter for Component Cable? Can someone Help as to how I can connect multiple devices using Component Cable since I only have 2 inputs on my Amp and only 1 on the TV? Thanks |
New member Username: Tf220
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 18, 2007 - 03:36 pm: |
I have connected an LG DVD player to a Samsung TV via the Composite Video & Audio conections - quality was good. However, when I connect the two units together via the Component sockets, the quality is a lot worse. I used the same normal Composite Cables for both the tests, ie two screened wires for audio & a slightly thicker screened wire for the video (red, white & yellow). could it be that you need a different / thicker set of cables for the Component connections to give the better pictuer quality? |
New member Username: Dishman56
Post Number: 1 Registered: May-07
| Posted on Thursday, May 03, 2007 - 12:32 pm: |
Would high quality RG56 coax with compression F connectors using the Male RCA to Male F connector adaptor make a good high end 720P 1080P component cable |
New member Username: Matto1985
Waltham,
MA
Post Number: 3 Registered: Jun-07
| Posted on Tuesday, July 17, 2007 - 04:37 pm: |
In regards to some of the early responses you can find high quality, moderately priced cables at www.tendonusa.com. They are just as good as monster cables, but much less expensive. |
New member Username: Soundidiot
Post Number: 1 Registered: Jan-08
| Posted on Friday, January 11, 2008 - 06:43 am: |
HELP PLEASE!! i have a fujitsu plasma DISPLAY unit (no tuner built in)and i would like to watch SKY on the plasma display. The display unit has a "video component" connection which consists of three BNC connectors. Can i get a scart to vide component cable with BNC connectors. I guess if i coonect the scart lead to the SKY box and the BNC connectors to the diplay unit i should get the picture on the display unit? For sound i guess i can plug normal PC audio speakers into the sky box phone connections as the display unit has no speakers. I have now purchased loads of different cables and cant seem to get a correct answer. Any advice will be greatly appreciated. |
New member Username: Richy88
Singapore,
SG
Singapore
| Posted on Monday, January 21, 2008 - 10:15 am: |
Hi Can someone tell me whether is there any difference between the AV cable (Yellow/White/Red) and the Component cable (Red/Green/Blue)? Are they interchangeable and is there any quality difference, apart from the price. Many thanks in advance. |
New member Username: Tobytyke
Post Number: 1 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 02:02 pm: |
Hi, I am trying to capture a frame from a component RGB signal. Background A very old system outputs from three 75 ohm BNC connectors to a monitor. The sync is on the green signal by the way. The user has the option to print the view on the monitor. At the present time a very old frame grabber made by seiko captures a frame and then sends it to a compatiable seiko priner via a special video cable that only this type of printer uses. Trouble is printer is now broken and obsolete. I was hoping to be able to use a PC or laptop to capture a frame and then somehow print it. I have a small box made by a company called video express that I wanted to try out, but it only has one s-video input or the RED, Yellow & White phono inputs. The software that comes with the box captures the frame or video. But I somehow need to convert it to s-video so that the box can recognise it. Does anyone know if this is possible. Failing that does anyone know of a cheap video capture card that can capture video in on 3 component BNC cables. Last option I guess is to input to a video recorder or DVD who's output is capable of being captured. Any help appreciated Thanks |
New member Username: Bellboy21
Post Number: 1 Registered: Jul-08
| Posted on Tuesday, July 01, 2008 - 11:57 am: |
I would like to connect a HD TV box to a Hard Disc Recorder using the Component ports. The supplied cable has three "RCA" connectors, each end. - Red, Yellow and White. Will this work for me? Obviously I will have to respect the Green , Blue , Red sequence. BB |
