Home > Message Board > Articles > Archive through December 30, 2005 > How Speakers Radiate Sound: Why Wall ...
How Speakers Radiate Sound: Why Wall Units are the Enemy?
[ Create New Article ] [ Reply ] [ Edit ]
When we see a forward-firing loudspeaker facing us, it seems reasonable to assume that it is radiating its sound output toward us, producing little or no sound to the sides and rear. After all, it's called a "forward-firing" speaker, correct? And its drivers are all mounted on the front panel of the speaker enclosure, facing the listener.
But this simple label overlooks an important aspect of loudspeaker performance that becomes crucial when home theater fans want to place speakers into a secondary enclosure like a big, custom-designed wall unit with special cavities intended to accommodate floorstanding speakers.
Axiom M60 or M80 tower speakers, for example, have fairly tall, somewhat deep cabinets, tapered towards the rear, with typically one or more rear-facing ports. The enclosure volume, multiple ports, and narrow front baffle all contribute to smooth, extended bass response and a spacious soundstage. If you want deep bass, a relatively large enclosure is a fact of life in speaker design. That is a basic law of physics that can't be circumvented. Consequently, larger speakers occupy more space in a person's home. And that gives rise to certain issues.
Axiom customers who want to preserve domestic bliss reluctantly yield to spousal or partner requests that no speaker boxes of any sort be visible in the room where the entertainment system resides. Hiding the boxes inside a wall unit seems the perfect compromise. Customers frequently email me, asking if it's OK to go ahead and install a pair of M60ti towers in an entertainment center. Despite my advice not to, one recent Axiom customer did it anyway. He called last week and reported that his M60s sounded "so much better" when he pulled them out of the wall unit and listened to them out in the room. His wife's approval remained a big, unresolved issue, and we discussed alternatives (dump the wife? Just kidding. . .), including wall-mounting a pair of M60ti's or, as I suggested, suspending them from the ceiling.
Large wall units or entertainment centers are sensible solutions to house an A/V receiver, DVD player and other gear as well as the TV display. But putting tower speakers inside the wall unit will degrade and compromise Axiom's neutral and transparent sound.
Why does this happen? Much of the evidence gathered so far is based on my own observations over many years as well as anecdotal reports from Axiom owners.
The reason that a well-designed loudspeaker sounds neutral, natural and "musical" when it's heard in an ideal setup away from room corners, ultimately depends on the speaker's "linearity," the technical term for the smoothness of the frequency responses that are radiated directly forward and at increasing angles to each side. The "off-axis" radiation at angles to each side is important because these are the sounds that are reflected laterally from the walls. Dozens of measurements of a speaker's output into the area of space in front of the speaker (the front "hemisphere") show that if the frequency response of the speaker remains smooth and consistent over a broad angle, the speaker will be musically accurate and free of tonal "colorations" and distortions that lessen the realism of the reproduced instrumental sound.
If we listen to instruments facing toward us in a live setting (think of horns, reeds, and woodwinds), the complex wavefront that represents the "sound" or timbral signature of a particular instrument is composed of fundamental musical tones plus harmonics that are generated by the resonances within the pipe or tube of the instrument. This combination of tones and overtones create the sonic signature for every instrument, and even establishes the unique character to our own voice. This complex mix of tones and overtones is radiated instantly and simultaneously, reaching our ears intact. If the instruments face away from us, they sound different, because the makeup of the instrument's set of fundamentals and overtones has changed.
Instruments have far-field reflections, not near-field reflections, so if you put a musical instrument inside something, you change the radiation characteristics. You create near-field reflections that happen too soon, so the frequency response and the spectrum gets distorted. (For exactly the same reason, you don't play your guitar facing the wall.)
Loudspeakers work the same way. When the designer knows the way the loudspeaker responds over a broad set of angles in a test setting (he has examined a "family of curves" — the speaker's frequency responses into a broad space in front of it), he knows that when the speaker is placed in a room it will continue to disseminate its energy in the same manner, so there is a high degree of probability that the loudspeaker will continue to deliver its wavefronts accurately, and it will be heard that way by listeners in most conventional domestic rooms. In the development of a loudspeaker prototype, great care is taken to investigate and correct any deviations from smoothness or linearity. Even the destructive interference and resulting frequency response glitches caused by edge diffraction from the physical edges of the speaker's front baffle or the speaker grille frame and grille material can be documented and fixed.
Knowing this, it's not difficult to understand what happens when you put a tower speaker (or a bookshelf model) inside a wall unit, credenza, or entertainment center. The surfaces in the wall unit's cavity at each side and above and below it, create a set of near-field reflections that don't exist when the speaker operates normally unencumbered by cabinetry. These cancel and reinforce at various frequencies, affecting the linearity of the system and producing all kinds of nasty anomalies and unmusical colorations.
Of course, this is a simplified explanation of how a loudspeaker propagates its sound into a room, but the message is clear. For the speaker designer, it is difficult enough to fine-tune the loudspeaker's horizontal and vertical on- and off-axis frequency responses to achieve a linear system that has a reasonable probability of delivering smooth, spacious, and uncolored sound reproduction given the speakers are allowed to operate in relatively free space in a room. Changing that formula by hiding speakers away in enclosures will undo all the efforts of the speaker's designer to create a smooth, accurate, and musical sound reproducer.
by Alan Lofft (bio), Axiom Audio (reprinted with permission)
Relevant Product Info
Author Comments
why not just get dipole electrostatics? Martin Logan all the way! :D
gavincumm
I agree!!! ML, Innersound, or maggies!!!!!
David Francis
Interestin when most sound recording studios have their speakers built into the walls and these provide the reference for the recorded music we listen to. Nothing is exact or perfect in sound reproduction and my only suggestion is that people with wall units would never compromise the design of their speakers, so commonsense would mean your boxes are not appropriate for this purpose. All things in their place. Keep it simple.
A dipole speaker sends as much energy to its rear as it does to the front. Sticking a pair of those into a wall unit would be even worse than the situation Alan Lofft is describing. Recessing speakers into a wall presents a different set of acoustical challenges than a wall unit. In fact, the fundemental flaw with most in-wall speakers is that they are installed up high, we listen to them from down below. The wave intereference between the woofer and tweeter that conventional crossovers permit will cause deep peaks and dips in the response- resulting a hollow nasal sound. The new JosephAudio Insider in-wall speaker has a patented Infinite Slope crossover so it sounds clear everywhere. At the recent HE 2004 show, a pair of these behind curtains fooled many listeners into thinking they were hearing a pair of large freestanding speakers!
Home > Message Board > Articles > Archive through December 30, 2005 > How Speakers Radiate Sound: Why Wall ... [ « Previous ] [ Next » ]
