Getting your local channel
| Posted by Anon on Tuesday, January 11, 2005 - 12:43 pm: |
When it comes to television networks, local programming is an important issue to be considered. Of course you want those national channels for your primetime TV shows, but local programming is what keeps you stay connected with community in your area.
Since the issue is concerned by most of us, lets do some comparisons between cable TV and satellite TV on this local TV channels selection issue.
In United States, cable TV packages normally have some local programming in their services your area. Typically you will get a few local news stations, or maybe a local supply of NBC or CBS channels based on your area. Large cities like L.A. and N.Y. users will also have an independent local channel that showcases local events and community. Such TV channel is great for local publicizing, events sharing as well as staying connected.
For digital cable providers, time shifting can be used for adjusting your show time. This means that one program will be on at several different times. This is a great feature to ensure you never miss your favorite shows or news.
Sounds great? But it can be greater if you are satellite TV deal's users.
Cable TV packages only provide you basic programming packages with very limited local channels choice. If you go with satellite TV services, you can have much more selections as well as the time shifting advantage with around the same monthly cost (or in fact, it’s even cheaper).
Instead of only having your limited local programming choices on your list, you may get local channels from other cities and towns close by as well. Through this, you can keep up with what's going on not too far around you. Stay connected, stay updates, and stay alert with all those interesting events as well as incidents happening around your city, and city near by.
[ « Previous Article ]
[ Next Article » ]
