Home > Message Board > Articles > Archive through December 18, 2007 > How to Buy Video Cables
+ Share | Create New Article | Reply | Edit
Cable Quandary: Composite, S-Video, Component Video, DVI, and HDMI Connectors
At Axiom we take a rational, scientific and no-nonsense approach to cables in general, speaker cables in particular. If it's good-quality copper and it's thick enough for a given length (we like 12-gauge for speaker cable runs longer than 15 feet), then the cable's resistance is low enough to prevent any audible or sonic degradation. We also take a dim view of assertions made by many sellers of exotic, costly branded speaker cable as to scientifically unproven claims of vastly improved sound quality. All of the careful scientific tests in which we participated at Canada's National Research Council have shown no improvement whatsoever in costly exotic speaker cables over good-quality copper of 12-gauge or 14-gauge in lengths up to 30 feet.
Composite VideoAnalog Audio/VideoComponent VideoS-Video
UploadUploadUploadUpload
Make the Connection
But what of video cables? To steal a line from ol' Bob Dylan, "the times they are a 'changin'." Most people have hooked up a VCR or DVD player to a receiver or a TV set using a simple shielded RCA Video "interconnect." It is by far the most common type of audio and video connector, so-named because of the small, male, single-pin "RCA" plug at each end of a shielded, coaxial cable. (A coaxial cable has an outer braided metal shield and an inner copper conductor, with a non-conductive insulation or "dialectric" sandwiched in between). The woven outer shield prevents RFI (radio frequency interference) and EMI (electromagnetic interference) from getting into the cable and degrading the video signals. It is commonly used for composite video (a single cable, often color-coded yellow), S-Video, and component-video connections, the latter consisting of three shielded cables (coded red, green and blue), which keep the color and luminance (brightness) signals separate from each other. Composite-video (single cable, RCA plugs), S-Video (single cable, multi-pin connector), and component-video (three cables, RCA plugs) are all analog video connectors. But there are important differences in the functions of video interconnects compared to audio interconnects.
Video Highs
Coaxial analog-audio RCA interconnects only deal with audio frequencies, a fairly limited bandwidth from 10 Hz to 20 kHz or a bit higher (the "k" means 1,000, so 20 kHz is 20,000 Hz). But video cables must routinely pass high frequencies of 12 MegaHertz (MHz) -- "mega" stands for 1 million-and for High Definition TV signals, the video cables must have a bandwidth of at least 35 MHz (35 million Hz) if the video frequencies are to pass from source to TV display without losses. If you get high-frequency losses in video, the sharpness and clarity of the image suffer. So if the cable is of poor quality, with excessive capacitance (too much capacitance produces high-frequency losses), the picture may be "soft," or blurry. For HDTV signals, it's worth using high-quality cables for even short lengths.
What do we mean by "high-quality" video cables?
Check the soldered connections at each end (unscrew the barrel of the connector if you can, and inspect the soldering. A messy soldering job may influence video losses.)
Good-quality component-video cables will carry analog progressive-scan video from a DVD player as well as High Definition video signals from an HD tuner, satellite receiver or cable box to a TV display either directly or via an A/V receiver's component video inputs and outputs. Note that the A/V receiver's component-video inputs and outputs should be "wide bandwidth" (meaning video bandwidth of at least 35 MHz or more) if they are to convey HD signals with no visible losses through the receiver's switching circuits. Ranked in terms of overall picture quality, component video usually ranks at the top, S-Video is next, and composite video is last.
Two New Guys: DVI and HDMI
Recently, two new types of connectors -- DVI and HDMI -- are appearing on the latest generation of HDTV displays and DVD players. DVI (Digital Visual Interface) is a big, clumsy, multi-pin plug and carries digital HD video (it may carry analog video as well but it is not a DVI requirement). HDMI (High Definition Multimedia Interface) uses a smaller plug that looks like an oversized USB plug. HDMI carries the same digital video as DVI but also adds conductors for a Dolby Digital audio data stream. In addition to new HDTV displays, some new HD cable or HD satellite boxes and "up-converting" DVD players may have one or both of these digital video output connectors. The DVD player will up-convert a DVD's 480i or 480p output signals to 720p or 1080i to match the HDTV display's native resolution. (See last month's AudioFile Newsletter for an explanation of "native resolution.") Both DVI and HDMI are high-speed digital connections that keep the video in the digital domain all the way from the HD cable box, HD satellite tuner or DVD player to the HDTV display, eliminating the extra digital-to-analog (D/A) and analog-to-digital (A/D) conversion that normally takes place with component video cables (remember, those are analog video connectors). The theory sounds impressive, and there has been lots of excitement and hyperbole about these new digital HD connectors. The rationale goes like this: If component-video cables are the best analog video connectors you can use, then DVI or HDMI digital video connectors must be better because they maintain the video in the digital domain all the way to the HDTV display, right?
Not so fast
The presumption is that if the conversion is done in the digital domain inside the DVD player, avoiding an extra conversion to analog (component video) and back again to digital when it reaches the HDTV display, then improved clarity and color should result. But here's where things get murky. What no-one is talking about is that even though the HD video is up- or down-converted and kept in the digital domain, when the digital video signal reaches the HD display in its native format, the digital TV still has to re-clock the digital video so that it exactly matches the TV's native resolution. And according to informed sources, re-clocking digital video may produce more picture degradation and video artifacts -- not less--than a good analog component-video connection.
It's All in the Chips
Two other factors come into play with DVI and HDMI that have the potential to cause video artifacts. The quality of internal digital video conversion chips may vary considerably from one product to another. Faroudja and Genesis produce some of the best (and most expensive) digital video processing chips available, but there are lots of cheaper options from other chip-makers that a manufacturer can choose from to keep manufacturing costs down. Moreover, the quality of video A/D and D/A converter chips has improved tremendously, which means that even inexpensive DVD players these days are likely to have excellent video D/A processing through the component video outputs. Finally, any device with DVI or HDMI outputs must carry a special digital anti-piracy code called HDCP (High-bandwidth Digital Content Protection) to thwart illegal copying. HDCP is mandated for both DVI and HDMI connections and uses an authentication protocol developed by computer chip-maker Intel. It involves the HD digital cable box or HD satellite receiver sending a kind of digital "hand-shake" to the HD receiving device (the TV display) to ensure that it's licensed to receive the HD content. These anti-copy codes are embedded in the digital video data stream and must be removed by the video processor in the HD display. Result? The display's internal video processor has to do extra digital "work" with no benefits to picture quality, so possible degradation may take place. Using the analog component video outputs bypasses the anti-piracy codes, so the TV display doesn't have to deal with the extra processing.
Cable Length vs. Image Quality
As to lengths of video cable, if the video output drivers of an A/V receiver are well-designed with lots of output, component-video can be carried over 50 feet without degradation. But with DVI or HDMI connectors, engineering and cable theory suggests that running lengths greater than 3 meters (about 10 feet) risks digital drop-outs and resulting pixelization. Additionally, the capacitance factor becomes very important because the bandwidth of the uncompressed digital video signals running in a DVI or HDMI cable is much higher than an HD component-video analog feed, and therefore more critical with longer cable runs. If the error-correction of the receiving device is robust, it may be fine. Otherwise, consider going analog component video.
Do Your Own Tests
One appealing aspect of video, of course, is that you can see the results of picture degradation, so you can try an analog component-video connection to your HD display and compare the results with a DVI or HDMI digital video connection. Look for any visible artifacts-noise in dark areas, frequent drop-outs or freeze-ups of the image-artificial "peaking" or sharpening of the image, with white halos around the edges of objects, as well as the overall sharpness and clarity of the HD images. Use the cable link that produces the most satisfying and realistic movie-like image.
by Alan Lofft (bio), Axiom Audio (reprinted with permission)
Author Comments
I have a component video connector made by Acoustic Research - Master Series Ms291 which I purchased a year ago. Can you tell me how it rates against some of the current products like Monster?
I can't seem to find info on the Master Series anymore.
no difference except in the minds of BEST BUY sales people
however you won't see any Coke vs Pepsi tests using actual humans, otherwise MONSTER w/b out of business
I appreciate this accompanying article and assume it is telling me that typically the two audio cables in a composite cable set carry less bandwidth than the single video cable. My question ... would three "video" cables from an AV composite set suffice to carry to component video signal.
As far as I can tell, AV and component cables are essentially the same. We have been using a standard set of red, white and yellow AV connectors for our component video for several years now.
There is actually a difference between the Monster cables and Acoustic Research if you care to look at the construction of the cables. Monster does use extra shielding with their cables to provide a better performance. I know this for a fact because have seen the insides of both of them. However, the performance of the two will be very similar to the untrained eye. However, if you have dealt with the video constantly you will see a difference in the detail of the image.
As to AV and Component being essentially the same, if you mean they are made of gold plating, plastic, rubber, some copper wiring then yes. But other than that they are completely different. Believe me if you hook them up one way and then try the other, you will defiantly notice a difference.
Username: Reinert
what is better for hd tv, monster component, or acoustic component
Username: Reinert
i bought acoustic component and monster thx last night, the component gold plated that came with cablevision was much sharper and clear than the acoustic, then tried the thx monster, outstanding crystal clear, moving object stayed clear, while the others were a litter blurry then adjusted - monster it is
Can a 75 ohm High Definition cable replace an audio coaxial cable?
zdz
In a blind taste test you'll NEVER hear/see the difference between Monster vs AR. You will however feel a 2:1 difference in wallet size.
Username: Bcm
as someone previously stated on here, i am using the standard red-white-yellow rca cables as my 3 component video connections. (and a second set for the audio) would there really be a difference in video quality if i ran out and bought offical "component video cable"?
Username: Tom_nk
There are a lot of different factors that go into effectiveness on coaxial cabling. How many layers of shielding are there? What is the attenuation/loss of the cable? Is the cable the correct length for the application? What type of connector is used? What type of coaxial cable is it?
You will want the cables that are the shortest for your application, the longer the cable, the more room for outside interference and the more the loss. If the manufacturer of the cable offers a chart showing frequency response, you should be able to make a more informed decision comparing the manufacturers.
If your standard RCA cable sets have a yellow that is thicker than the red and white, you probably could get away with using three sets, assuming the frequency range for component is the same. The thicker cable is likely shielded. The advantage to pre-fab component cable will be that the three coax cables will be ribbon'd together for a nice run from your video source to the TV. If your cables don't have the extra shielding, then you will probably see an improvement over your existing picture.
Disclaimer: I'm no expert in component video, I just know a little about RF cabling and have made some assumptions, which may be totally incorrect.
Username: Pharmboy
Does the picture fill the entire screeen when using dvi/hdmi as opposed to cutting off top/bottom with rca component cables?
Username: Rhiggy01
I am using a monster v100cv componet video cable for my hd programing with verizon fios. Should I be using a different componet video cable or is this one fine for hd.
Home > Message Board > Articles > Archive through December 18, 2007 > How to Buy Video Cables [ « Previous ] [ Next » ]
