What is Bi-wiring and Bi-amping?
Bi-words seem to be proliferating these days (bi-coastal, bipolar, etc.), and the world of stereo and home theater loudspeakers is no exception. The terms "bi-wiring" and "bi-amping" (short for biamplification) continue to confuse lots of stereo and home theater fans. At its root, "bi" means "two," and it relates particularly to the Axiom M80ti and M60ti tower speakers, which are supplied with "biwiring terminals." Biwiring in practice means running two speakers cables to each speaker (a total of four to a pair of speakers) instead of one cable per speaker.
On the M80's rear panel (and the M60's), there are four binding posts instead of the usual two. One pair of binding posts is linked to the woofers, and the other two are connected to the midrange and tweeter section of the crossover. When the speakers are shipped, there are gold straps that run between the two pairs of binding posts, linking them so that they function electrically as a pair. If you remove the gold metal links, however, you can biwire your speakers, using one speaker cable for the woofers, and the other cable for the midrange and tweeters. At the other end, both cables connect to the same amplifier output terminals. The practice became popular in Britain (not unknown for its eccentric audiophiles), the thinking being that using separate cables for low and high frequencies would somehow reduce interference between the two and improve sound quality. If you look at the amplifier as a current source, then for amplifiers and receivers that are capable of supplying lots of current into low impedances, biwiring could offer theoretical advantages, particularly to loudspeakers that are linear and smooth, like the Axiom M80ti and M60ti, by eliminating potential intermodulation distortion between the low- and high-frequency portions of the audio signal. Using biwiring, this distortion would not occur because the low-frequency part of the speaker crossover would draw the current it needs for the woofers (and they need lots of current) through one speaker cable, while the midrange tweeter section would draw less current (it doesn't need as much) through its own speaker cable. This could prevent intermodulation distortion that may occur using one big "fire hose" or single speaker cable. (Using two cables per speaker will also lower total resistance to the audio signal -- and that is well and good, although a single run of 12-gauge cable to each speaker will keep resistance to an insignificant level, well below 0.3 ohms.) Will it sound any different if you biwire? Some users think it does, but I've never heard any differences, nor have any of our laboratory measurements or scientifically controlled double blind listening tests ever demonstrated there are audible differences. Axiom includes the extra terminals as a nod to those enthusiasts who believe that biwiring results in audible benefits and for the bi-ampers. Bi-amping, or biamplification, is used mainly in professional sound reinforcement applications, where extremely high levels of loudness are required. Here big, separate amplifiers powering the low frequencies, and smaller amps for the midrange will increase overall output. Sometimes they will use a separate outboard electronic crossover (the speaker's internal crossover is disabled or bypassed entirely) so the operator can vary and adjust individual crossover frequencies, tailor the "slope" of the crossover to match the strengths of each set of drivers, and also adjust the relative sonic balance of bass, midrange and treble to suit the environment. This is important for huge auditoriums or outdoor events where separate arrays of treble and midrange horns are operating with big "bass bins," but such systems have no place in domestic home theater systems in normal rooms. Additionally, it puts control of the relative smoothness and tonal balance into the hands of the sound system operator, a dangerous tool for all but the most experienced sound reinforcement experts. It also partly explains why the live sound at so many concert events (not all, mind you) is so awful. by Alan Lofft (bio), Axiom Audio (reprinted with permission) |
Author
Comments
Bronze Member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 17 Registered: May-05
| Posted on Monday, May 23, 2005 - 03:47 am: |
I have put my JBL control 5 though the process of being active, I have taking two screws out of the back of the enclosure that holds the passive crossover, and placed two wires in the holes and have connected them to the bass mid. For the HF I have used the same input as before the passive crossover input terminals, and with two cable runs going back to the Marantz 1050 amp, and using a two-way electronic active crossover the soundlab professional audio. With the center output coming from the Kenwood KRF-X9050D THX select Dolby digital DTS AVR, and plugging into the an Technics SH-8055 12 band EQ then output from that and going to the active X-over, with the two outputs running into a Realistic 10 band EQ left and right one for the LF and the HF. The outputs then go to a Yamaha DSP-100, left and right inputs then outputting to the Marantz 1050, I have set it up using wide-band pink noise had to place a little boost on the LF at the middle range at 500Hz and 1KHz as it was too deep on the low end of the spectrum, and for the HF had to cut 2KHz down slightly, and the rest I had to balance the sound for a flat line using the microphone connected to the Technics SH-8055 12 band EQ microphone input and looking at the RTA took a little while too get it up and running. Still have a little more to do on it, and have been playing films like Die Hard and Die Hard 2 in Dolby six-track stereo as they offer good quality in there mixing techniques Hail to the re-recoding mixers. Wow this sounded a whole lot better, using an active crossover, passive as given me too much problems, over the years I have been not too happy with the playback of the centre channel, now it’s a whole lot of fun listening to a film, there is few errors, with it set up this way, the sound just disappeared into a whole new ball game and control over the sound as well. Now all I need is a few more active x-over networks for the left and right fronts and maybe the surround array that is side surrounds centre back surround and height surround. For the present time I’ll keep you updated on this. Thanks for placing this page hear its very good indeed. Ashley
