Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > HELP - Only 1 HDMI Input - TIVO or DV...
Author Thread: HELP - Only 1 HDMI Input - TIVO or DVD Player?
Username: Shatland
Just bought the new Mitsubishi WD-52525...Very happy with the TV. However it only has one "purely digital" input...1 HDMI input. I would like to get a DVD Player that upconverts to 720p, but I also have plans to buy the HD TIVO once the price drops to a reasonable level. Is there ANY WAY to do both (like a HDMI switch box, like they have for S-Video)? In the likely case I have to pick one, is it best to use the HDMI for DVD and then use Components for the HD TIVO?
Thanks for your expertise! Also, anybody have any idea when the HD TIVO is going to offered at a more realistic price?? Thanks!
ecapt
I have just bought the 52725 and have the same problem. Geffen makes DVI and HDMI switches for around $250 to $300. Has anyone tried these? If so are you happy with the quality. I am going to use comcast new pvr setup for the $5.00 a month it is alot less expensive investment then the TVIO. If you are using satelite the Dishnetwork also has a HDTV recorder that you can get.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > HELP - Only 1 HDMI Input - TIVO or DV... [ « Previous ] [ Next » ]
