Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Denon 1604 or 1804 with Mission speak...
Author Thread: Denon 1604 or 1804 with Mission speakers, help!
Username: Tmleafsfan93
I am new into world of home theater and I have decided to purchase a mission surround system and I am wondering which receiver to get. I am purchasing the mission m34 as my fronts, the m31 as my rears, the larger Mc2 for the center, and either the 8 inch or 10 inch mission sub. my questions are as follows:
1. I am planning to buy either the Denon 1604 or 1804 (definitely leaning towards the 1804). I this receiver a good match with mission speakers? Which of the 2 Denons would you recommend, and are there any other receivers I should consider purchasing to match the Mission m3 series?
2. Assuming I stick with Denon, is it worth it to spend the extra cash on the 1804, instead of the 1604?
3. Which of the 2 subs would you recommend, 8 inch or 10 inch? Not a large room, probably about 15 or 16 feet by 13 feet (just estimating).
All opinions will be greatly appreciated ... especially you Hawk, you sem to really know what you're talking about!!
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Denon 1604 or 1804 with Mission speak... [ « Previous ] [ Next » ]
