Thread: The Budget Buster!! |
New member Username: Braden
Post Number: 3 Registered: Sep-04
| Posted on Wednesday, September 08, 2004 - 10:21 pm: |
OK $1800-$2000 for speakers and receiver What to do with that in this room size: 45Lx15Wx8H Open space in rear of room 65in HDTV in front main sitting area about 18ft away.. rest of room is wasted space... HKAVR630--Refurb.......600 YamaHTR5760............350 Martanz?? Other suggestions SUBS HSU or SVS.............600 Fronts: Floor or book? Looking at Axioms/Ascends/JBL Matching rears... Also, going to go 5.1 for now but will upgrade to 6.1 in the near future... Any suggestions would be awesome, have been researching forever and ready to buy...
Post Number: 1420 Registered: Dec-03
| Posted on Thursday, September 09, 2004 - 08:03 am: |
Try these out. http://www.ascendacoustics.com/pages/purchase/advisor.asp#bottom Go for the CBM 170 all around with the HSU sub. An excellent set, you should be able to get a deal for HK receivers with this company, too. Impeccable service and knowledgeable folks. |
Post Number: 4 Registered: Sep-04
| Posted on Thursday, September 09, 2004 - 09:33 am: |
berny will those be enough to fill the room? which HSU would fit this room size? i have been told to go with SVS but not sure here?? also, would it be worth the extra money to upgrade to 340, or would the 170 do me... Novice here, need some expert advice.... Thanks Todd |
Post Number: 1423 Registered: Dec-03
| Posted on Thursday, September 09, 2004 - 10:51 am: |
It is always worth the extra money to upgrade , but that is just me. Unless you are planning on actually spacing the speakers through out the whole length of a 45 foot room then it would be advisable. Choosing between HSU and SVS is a tough choice, it would come down to which one you want to spend money on, as they are both worth the price. And both are capable of filling your room. |
New member Username: Tooch17
Post Number: 2 Registered: Sep-04
| Posted on Thursday, September 09, 2004 - 11:34 am: |
I know this has nothing to do with the subject, but i cant find help anywhere on this site and i see that you of you guys post alot. so i figured what the hell. i have a yamaha htr5760 receiver, sony tv, sony dvd, and ps2. i have a component cable connected from my dvd to my tv and then an analog cable from dvd to receiver. i have a monster component ps2 cable connect to the dtv/cbl connectors on the receiver. i am getting no picture from my ps2. what am i missing. can someone help? thanks |
Post Number: 5 Registered: Sep-04
| Posted on Sunday, September 12, 2004 - 02:43 pm: |
UPDATE............... Just purchased first peice of HT system HK AVR 630 for $641 delivered...is that good?? Ordering SVS sub 25-39PCi today....Any suggestions on speakers??? Stuck on Ascends or lower model of JBLs S312 and S38ii around.. Any suggestions??? |
Post Number: 1469 Registered: Dec-03
| Posted on Sunday, September 12, 2004 - 07:38 pm: |
Nice choices!! Go with Ascend Acoustics, a much better sounding than the JBL, at least tomy ears...could be different for you. |
Bronze Member Username: Hokievt
Post Number: 30 Registered: Aug-04
| Posted on Monday, September 13, 2004 - 11:24 am: |
Good receiver. You'll be glad you made that decision. |
Post Number: 6 Registered: Sep-04
| Posted on Tuesday, September 14, 2004 - 12:34 am: |
UPDATE AGAIN!!!! ORDERED SVS 20-39PCi.....This stuff is adicting, went way over budget with this, but what the heck, will just have to work a few extra hours.. Still have not decided on speakers....Any last thouhgts by anyone??? Ascends/Swans/Axiom/B&W??????? |
Post Number: 1487 Registered: Dec-03
| Posted on Saturday, September 18, 2004 - 05:24 pm: |
Still on Axioms |
