Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > DVD progressive scan problems
Author Thread: DVD progressive scan problems
Username: Tommyt
I hooked up my new progressive scan DVD player through my HK 230 receiver using component cables. When I push the progressive scan button on the DVD, the picture shows up as two pictures. The manual with the DVD player says if this happens then my TV won't accept progressive scan images. Is this right as the TV has mutiple component video inputs?
Username: Project6
Post Number: 1364
component video inputs does not necessarily mean progressive scan compatible. So, chances are your TV is no PS compatible. Sorry:-(
Username: Tommyt
That's what I was afraid of. Thanks for your answer. Oh well now on to an HDTV because the existing TV just won't work. Right? (Just practicing for my wife.)
Username: Project6
Post Number: 1399
Absolutely, plus let her know that in 6 years or even sooner, TV broadcasts will be in digital format so have to get a set that is compatible. You noticed that a lot of regular TVs with big screens are getting cheaper?
Username: Forcedinduction
Post Number: 43
Regular TV's are not progressive scan, they are interlaced. Progressive displays the whole image at once, interlaced displays do every other line over 2 scans.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 26, 2004 > DVD progressive scan problems [ « Previous ] [ Next » ]
