Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > How to add 5.1 HT to my existing ster...
Author Thread: How to add 5.1 HT to my existing stereo system?
Username: Dennislwl
Dear all,
I am new in 5.1 HT. I am now have an existing stereo system for listening music (a pair of speaker, stereo amplifer and a dvd/sacd player). How to expand my existing system to a 5.1 HT?
I know, i have to buy an AV receiver, 3 more speakers (center and surrounds) and a Subwoofer.
The problem is i want to use my stereo amplifer to listen music (only front speakers on). and use AV receiver on movie. How to connect all components together?
I really confused and need help. Thanks a lot.
Dennis
Username: Project6
Post Number: 1319
An AV receiver is also capable of doing stereo.
What you can do is use the pre-amp output of your soon to be AV receiver and hook it up to your older stereo system. Use said stereo system to listen to just stereo music.
NEW HT RECEIVER --> OLD STEREO --> Front left/right speakers
NEW HT RECEIVER --> Center speakers, Left/Right Surround speakers.
Username: Dennislwl
Excellent! Thanks Berny,
But if connect like this, Does the HT receiver will affect the quality of the stereo sound?
How to control the volume in HT and stereo mode?
Thanks
Username: Project6
Post Number: 1329
The quality of the stereo sound will depend on the receiver you will be using. It does not mean it will be bad.
The volume control for everything will be done by the HT receiver. But you can also make adjustments on the stereo amplifier.
Username: Dennislwl
Thanks again Berny,
Why i asked about whether the coming HT receiver affect the stereo music quality, is becasue it directly affect the choice (hi-end or low-end) of the receiver. I think i will use 70% music and 30% movie. So, Stereo quality is important. If the HT receiver affect the stereo quality, Maybe i should choose more hi-end HT receiver. (But it will make my stereo amp's exist no sense!).
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > How to add 5.1 HT to my existing ster... [ « Previous ] [ Next » ]
