Thread: Speakers for Yammy 5760 |
| Posted on Thursday, September 02, 2004 - 05:17 pm: |
I am getting Y5760. what speaker packages go well with 5760? I am mostly into rockm blues and metal. thanks |
Post Number: 1306 Registered: Dec-03
| Posted on Thursday, September 02, 2004 - 10:52 pm: |
any budget...5.1, stereo, etc.??? How about a little more info? |
| Posted on Thursday, September 02, 2004 - 11:19 pm: |
sure, I was thinking of 5.1 package but now I realize that I should start with stereo main speakers since I will use it primarily for music rather than movies. Budget: 250-400. for main speakers. thanks. I also plan to use iPod and laptop as the source so if you have any recommendations on that side, please help me. http://forum.ecoustics.com/bbs/messages/1/93002.html I noticed that you are a resident guru on digital music field. thanks! |
Post Number: 1308 Registered: Dec-03
| Posted on Friday, September 03, 2004 - 06:16 am: |
Check out the Ascend Acoustics cbm-170 for $328 a pair. An unbelievable set! http://www.ascendacoustics.com/pages/products/speakers/cbm170/cbm170.html And equally awesome would be the Axiom M22Ti for $400 a pair can't be beat. http://www.axiomaudio.com/m22ti.html The Ipods and laptops will have its limitations fidelity wise, but I suspect you wouldn't mind too much, unless you start getting into high resolution sources. cheers |
