Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Athena AS-B1 or Fluance AV-BP2 surrou...
Author Thread: Athena AS-B1 or Fluance AV-BP2 surrounds?
SLee
My room is 17' x 24' x 8' - usage will be 75% movies, 25% music. I've purchased an Onkyo tx-sr601(85w/ch) receiver and wish to put together a 6.1 speaker system for $7-800.
The floors and center will likely be Fluance SM-938 and Fluance AV-SC. These SM-938 floor speakers are rated 20-200w, so this receiver should drive it without problems, right?
For surrounds, I like the Athena AS-B1s, should I get the Fluance bipolars AV-BP2 to match the fronts and center? Has anyone here heard both models to give a recommendation?
I'll likely buy a Velodyne CHT-12 sub for $250 or so...
Suggestions, recommendations, comments? Thanks ppl:-)
Username: Project6
Post Number: 1280
Seems like you have this one figured out. Stick with the Fluance at the rears, you should be fine. The Velodyne is an excellent sub. Do a mini review when you have everything put together:-)
cheers
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Athena AS-B1 or Fluance AV-BP2 surrou... [ « Previous ] [ Next » ]
