Thread: Paradigm or Axiom Surrounds? |
Car Ramrod Unregistered guest |
| Posted on Saturday, August 28, 2004 - 12:28 am: |
I'm looking at ADP-170s or QS-4s. Haven't heard them but can get either for around $300 a pair. The ADP's have a 5 out of 15 reviews on audioreview and people seem to love the QS-4/8s too. Also, I would probably be needing a rear channel too and haven't seen the ADP-170's sold individually. Any thoughts? |
Post Number: 1246 Registered: Dec-03
| Posted on Monday, August 30, 2004 - 07:19 am: |
I'd get the Axioms. But everything is up to your ears, you have to listen to them and you will know which ones you like. Both speakers are excellent and people tend to like one and or the other. What receiver are you using? |
New member Username: Rscarb
Post Number: 3 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 10:46 am: |
I agree with Berny, go with the Axioms. I sampled them three weeks ago and was *amazed* at the acoustic range of these speakers. But a key factor is the receiver. Choose wisely is my opinion..
Silver Member Username: Elitefan1
Post Number: 685 Registered: Dec-03
| Posted on Monday, September 27, 2004 - 05:05 pm: |
What mains do you have? That would be helpful. I do not like to mix brands so if you have one or the other then that would be my recommendation. If not then what? |
Post Number: 4 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 06:29 am: |
I do not own the Axioms, I am looking for speakers to accent my HK AVR630 that I recently purchased. I went and listened to the Axiom M80ti's and the QS8's with the VP150 center. I can honestly say they sounded better, IMHO, than the Paradigms. But again let me stress how important the receiver is to the equation. I would spend *most* money on the recevier and then build your speakers around them. Just my opinion. |
Post Number: 686 Registered: Dec-03
| Posted on Tuesday, September 28, 2004 - 09:03 am: |
The "most" money in any system should be spent on speakers not a receiver. It is still impossible to recommend surrounds without knowing what mains someone has. |
Post Number: 5 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 11:09 am: |
I hear what you are saying but I disagree. If you have outstanding speakers and a mediocre to sub-mediocre receiver you may have speakers that sound like mud. A scratchy signal makes top line speakers sound like scratch.We could debate this but my limited experience has taught me to start with a quality signal and buy the best speakers you can afford. This is only my opinion, I do not want to upset anyone. |
hedonio Unregistered guest |
| Posted on Tuesday, September 28, 2004 - 11:46 am: |
There is a big difference between di-polar speakers and bi-polar speakers! The Paradigm have a di-polar arrangement and the Axiom have a bi-polar arrangement. Both design suppose to "diffuse"the sound. The opposite drivers layout on the di-polar (180deg. typically) will work off-phase (it was good when prologic first came out), while the bi-polar drivers (90 deg. separation) will work in-phase. Various variations of both designs, thanks to avance cross-over designs, will achieve great results for both, home theatre and multichanel music. Home theatre requires the surround sound to be diffuse while multichanel music requires to locate each channel sound. |
