Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Home theatre room setup
Author Thread: Home theatre room setup
Sasha
I would appreciate a home theatre recommendation for a 12'X13' room (8' ceiling). The room has carpeted floor, sheetrocked walls and ceiling....no windows. Interested 80/20 movies/music.
Username: Boca
Post Number: 9
Do you prefer HT from box or you would buy components separately: AV Receiver, speakers, DVD and so on.. What is your plan or let say how much
would you spend...
Username: Littleyama
I have a 191/2'x15' room w/ 18' vaulted ceiling. Behind the sofa where we will be viewing/listening, one side (19') is all windows.What can I do to prepare this room to get the best possible sound? What can I do accoustically for this room?
In reference to the above question. I plan on buying components separately.I would like to spend about $8-10K for T.V. a/v receiver,speakers.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through April 01, 2004 > Home theatre room setup [ « Previous ] [ Next » ]
