Home > Message Board > Home Theater > Surround Sound > Archive through December 27, 2004 > Loud Music, Quiet Vocal. NAD t760
Author Thread: Loud Music, Quiet Vocal. NAD t760
Username: Thorndean
Dublin
Ireland
Hi, I have a NAD t760 and T550 and am having some trouble..
All connected a running however the vocal when playing DVD's is far to quiet. I have adjusted center speaker to be louder but not really much better...any tips appreciated...Thanks
guest
I've had a similar problem because i like very clear dialogue during movies. Try turning down surround volume and move center channel up to +4 or +6. I also tipped center channel speaker down a bit to my listening level. If these steps don't work, you may need to upgrade center channel. What are you currently using?
Home > Message Board > Home Theater > Surround Sound > Archive through December 27, 2004 > Loud Music, Quiet Vocal. NAD t760 [ « Previous ] [ Next » ]
