Thread: Durabrand |
york1444 Unregistered guest |
| Posted on Monday, August 16, 2004 - 05:53 pm: |
I was looking at buying a Durabrand Home Theater at Walmart, the $50...wanted to know how much am I going to spend in wiring or anything else to get it to work... Is it ready out of the box, or am I going to have to spend another $50 in cables and stuff... |
Relevant Product Info
| Posted on Saturday, August 21, 2004 - 01:11 pm: |
I have a Durabrand HT-440 home theater system and I lost the remote for it. I was wondering if someone could tell me where I could order one on the net. |
darth vargi Unregistered guest |
| Posted on Saturday, August 21, 2004 - 04:54 pm: |
Everything should be in the box already if it is a HTIB solution |
| Posted on Monday, August 23, 2004 - 11:15 am: |
Help! Bought a Durabrand HT 395 and hooked it up to a 28" RCA TV and SONY DVD player (both fairly new) and now the TV rolls frequently and we often get a distorted band across the top of the screen. We do NOT have a VCR attached. Any ideas? The rolling is driving us insane. By the way, the sound is excellent. Thanks! |
Bronze Member Username: Hokievt
Post Number: 18 Registered: Aug-04
| Posted on Monday, August 23, 2004 - 01:49 pm: |
How did you connect it to the TV? |
| Posted on Tuesday, August 24, 2004 - 02:53 pm: |
My husband hooked it up. Right now, I can't tell you any specifics. I'm wondering now if it is the TV because I've found a lot of info about larger RCA TVs rolling. All of the speakers work well, but the image rolls whether it is a DVD or Playstation 1 game. The games only roll rarely. I'll post again when I have more details. Thanks. |
| Posted on Wednesday, August 25, 2004 - 10:14 am: |
Our HT 395 is hooked up according to the diagram on page 13 of the manual, without the optical cable. Our box did not include an optical cable. We have one video cable running from the HT video out the the back of the TV, video in. We have one video cable running from the DVD player video out to the HT video in. We have one coaxial cable running from the DVD digital/coaxial plug to the coaxial plug in the HT. We experience frequent rolling of the screen and occasional distortion across the top of the screen. I've noticed the TV rolling with certain sounds in the DVDs. Any ideas? Should we use a different cable configuration?? Thanks! |
wathomas777 Unregistered guest |
| Posted on Thursday, September 02, 2004 - 11:48 pm: |
Teresa, Two questions. One, is your center channel speaker sitting directly on top of the TV? If so the magnetic cone of the speaker may be interfering with the picture tube. If you have a "cabinet" that the TV is in (like a home entertainment center) stick the center channel speaker on that, or mount it on the wall in line with the left and right fronts. If that isn't the problem, then don't use the video portion of the HT at all. It's not necessary. I am assuming that your RCA TV at least has two video inputs. Even my 170 dollar RCA 27 inch has one Svideo jack and two sets of video inputs (RCA) If that is the case, run SVideo from the DVD (purchase an Svideo cable, it is worth it) and then Hook the PS-1 to the video jack in the front of the TV directly. My RCA can't use the rear RCA video-in jack and the SVideo input at the same time, so to hook up my VCR, I have to run the RCA video input around the back of the TV and plug that into the front Video Jacks. The point is, if your TV has enough video inputs, don't bother using the HT's video in and out jacks. If you have the open jacks on the TV, hook all your video inputs directly to the TV, and then use the HT for sound processing only. Hope this helps. |
| Posted on Saturday, September 11, 2004 - 09:45 pm: |
Thank you for all the helpful hints! We are going to try this as soon as possible. I appreciate the time you took to address my problem in such detail. Thanks again! |
| Posted on Saturday, September 25, 2004 - 03:13 pm: |
Have a Durabrand dwt1304 TV atached to a RCA vcr-plus. Cannot locate code number to operate the tv with RCA universal remote to record |
gleepsie Unregistered guest |
| Posted on Thursday, December 30, 2004 - 12:23 pm: |
i have a durabrand dwt1304, and can not get the 'game'/'external input' to actually show the video from my playstation 2 onscreen |
| Posted on Wednesday, January 05, 2005 - 06:46 pm: |
show d I buy from 2almart? Do they ship fat? Do they ship safely? Are they return poilicy good? I want buy a tv a computer and a sapeaker system from them is the durabrand nzmameany good? How about a 199 computer complete? 40gb sempron 2200 128 whoping megabityes of ram ddr kind is that a good gderal? |
| Posted on Thursday, January 06, 2005 - 12:03 am: |
WTH? |
| Posted on Saturday, February 12, 2005 - 12:29 pm: |
I have puchased a durabrand ht-395 and when I hook up my dvd player the screen randomly cuts out every once and a while. It does not, however, do this when my x box is hooked up to it. I tried moving my speakers away from the tv (though if this were the problem it would do it with the xbox too, right) and that did not solve the problem. My tv has only the antenna plug-in on the back so I do have to run the feed from the reciever through a converter, so I can't hook up the video through some other port. What can I do? |
| Posted on Monday, February 14, 2005 - 10:59 am: |
I am thinking about getting a Durabrand T'V set, are they any good? |
Fluffy White Unregistered guest |
| Posted on Friday, February 25, 2005 - 08:20 pm: |
Well it seems that I can not find anyone else who has had the same expirience as me, but I will be contacting durabrand shortly about it. A few days ago I had my $50 Durabrand reciever in subwoofer case playing. When I started to turn up the volume, I heard a crackle. I turned it off and saw?heard a pop from the middle of the plug. Then, a small puff of a flame came out the front of the sub's tube. After a hurried debate of what to do, I quickly threw it out my window (second floor) and promptly extinguished the flame. Weird huh? |
laagrindle Unregistered guest |
| Posted on Saturday, March 19, 2005 - 10:52 am: |
i have a sts75e durbrand surround system wonder how hook it up to a tv |
| Posted on Friday, April 08, 2005 - 08:08 pm: |
We purchased a Durabrand TV set in January 2004. In February 2005 after a power surge, we are unable to turn on the TV. Could you please give us the name of a repair store in Burlington, Ontario, Canada, where we can have this problem fixed? Thank you. |
| Posted on Tuesday, May 17, 2005 - 06:34 pm: |
I bought a second hand Durabrand TV at an auction. (it was a good price!) But when I got it home, the remote didn't work despite three battery changes. Any suggestions? Jo |
| Posted on Tuesday, June 07, 2005 - 10:06 pm: |
Just wondering if you found the code for this tv to program your remote with. I am having the same difficulty. Thanks. John |
Ed drouin Unregistered guest |
| Posted on Sunday, June 26, 2005 - 04:25 pm: |
where does the woofer go i bought ht 395 second hand with no instructions. thanks |
| Posted on Saturday, July 02, 2005 - 04:58 am: |
Any codes for STS98 home theater system for the One For All universal remote control? |
Martin88 Unregistered guest |
| Posted on Tuesday, July 05, 2005 - 08:25 pm: |
Does the Durabrand ht-395 from Walmart play DVD +R/RW? Just wanted to know before I bought it. Thank you. |
Andre71 Unregistered guest |
| Posted on Friday, July 15, 2005 - 12:05 pm: |
I bought a second hand Duranbrand Home Theater System (HT-395). I tried to connect TV, VCR and DVD to the system so that the sounds will go through all the speakers. The perfect sound going through the speakers when I played DVD, whereas big noise occured when TV and VCR were turned on. Any suggestions? Thanks! |
| Posted on Friday, July 22, 2005 - 01:38 pm: |
I bought a Durabrand DVD player with Karaoke and the DVD player works great but the Karaoke will not play store bought cd-g Karaoke cd's. Just wanted to know if anyone has had that problem and knows what to do to fix it. Thanks. |
not a redneck Unregistered guest |
| Posted on Tuesday, August 02, 2005 - 04:31 pm: |
only rednecks and people on welfare buy stereos at walmart (and sing karaoke heehaw) |
Silver Member Username: Joe_c
Oakwood,
Ga
Post Number: 805 Registered: Mar-05
| Posted on Tuesday, August 02, 2005 - 04:35 pm: |
Only rednecks feel the need to put others down cause they got nothin' better to do. |
walmall blows Unregistered guest |
| Posted on Tuesday, August 02, 2005 - 04:48 pm: |
sounds like youve been hittin the moonshine jojo |
| Posted on Sunday, August 14, 2005 - 07:54 pm: |
I need to locate an instruction book for my 20" durabrand tv |
Bronze Member Username: Shamuchef
Orlando,
Florida
United states
Post Number: 13 Registered: Aug-05
| Posted on Monday, August 15, 2005 - 07:15 pm: |
what do want to know
Got yer redneck Unregistered guest |
| Posted on Friday, August 19, 2005 - 07:44 pm: |
Oakwood, Ga. talk about rednecks, isn't that the redneck capitol of the world. |
New member Username: Bradfocker
Post Number: 1 Registered: Oct-05
| Posted on Saturday, October 29, 2005 - 07:42 pm: |
The Durabrand HT 395 is not a dvd player. Just a sourund sound system. Mine works great. I have a HT 400 to. Both are good for the money. |
| Posted on Friday, November 04, 2005 - 03:30 pm: |
is there a universal remote code for a durabrand home theater system with a dvd player |
New member Username: Untouchablecat
Post Number: 1 Registered: Dec-05
| Posted on Tuesday, December 13, 2005 - 01:07 am: |
have a durabrand HT3916 system. It's for a renter home. what is the max. spacing each speaker should be to get best sound. |
| Posted on Wednesday, December 28, 2005 - 06:35 pm: |
i bought a durabrand dvd home theater system and tried to hook everything up my dvd/cd player worked with the speakers but my tv did not workwith the speakers i have a 52 inch rca hdtv equipped tv please help |
| Posted on Wednesday, January 04, 2006 - 04:32 pm: |
I would like to know if Durabrand has any webpage and if these products can be purchased outside a retailer. |
| Posted on Wednesday, January 04, 2006 - 04:34 pm: |
| Posted on Friday, January 06, 2006 - 04:24 pm: |
I have the durabrand home theatre system 100 watt 5.1 channel surround sound system and i got it at walmart for the family for christmas. The first time i hooked it up the left front speaker wouldn't work but then we tried the speaker in a diferent jack in the back of the subwoofer and it worked fine. SO i took it back and got another and it has the same problem can some tell me if im doing anything wrong |
| Posted on Friday, January 06, 2006 - 04:40 pm: |
I got a new MP3 Durabrand player for Christmas, and I CAN'T GET THE SONGS ON IT! It's saying that I need to go into "My Computer" then go into "Removable Storage" section! But I don't have a Removable Storage section in"My Computer!" So... how do I get the songs on? This MP3 is very confusiong to use, and I've been trying to get it working for a long time, now! Please help!!!! |
| Posted on Friday, January 06, 2006 - 08:17 pm: |
I recieved as a gift a Durabrand DVD Home Theater System and I have a PS2. It is anyway that I can hear the games that I play through the system. I notice that my system only have Audio out. Can you Help me. |
New member Username: Ghyni
Bayamon,
Puerto Rico
Puerto Rico
Post Number: 1 Registered: Jan-06
| Posted on Friday, January 06, 2006 - 08:19 pm: |
| Posted on Wednesday, January 11, 2006 - 12:50 pm: |
i received a durabrnd dvd with surrond sound but the sound only works with the dvd player it will not work on only the tv does anyone know why |
| Posted on Monday, January 16, 2006 - 10:09 am: |
I received a Durabrand Home Theater system HT-3915 for Christmas. When we installed it one of the speakers did not work. We moved the speaker to another jack in the subwoffer and it worked. So one of the subwoofer outlets does not work. What do i do??? |
give me a brake Unregistered guest |
| Posted on Monday, January 16, 2006 - 01:06 pm: |
bring that f u c k i n piece of s h i t walmart crap back to the store and get a real home theater in a box you cheapskate |
Commonsense Unregistered guest |
| Posted on Wednesday, January 18, 2006 - 07:32 am: |
Wal-Mart = Low prices Low Prices = Low quality Low quality = cheap cheap = junk get the picture? Think of Wal-Mart for Toilet Paper and Underroos not Stereo Equipment. Besides Wal-Mart has sold America to the Chinese right under our noses. They close down our manufacturing plants and replace them with Wal-Marts for us to work and shop at. What happens next? Check your labels, ya cheap bastids. |
| Posted on Wednesday, January 18, 2006 - 07:51 am: |
Wal-Mart: Official Home of NASCAR 'Nuff Said |
| Posted on Friday, February 03, 2006 - 06:50 pm: |
I lost the remote to my durabrand ht 395 home theater system and would like to know if my direct TV can be programmed with the code to control it. If so, does anyone know the code to this system. I have found where I can buy a replacement remote but it is definitely not worth that. |
New member Username: Lions6958
Post Number: 1 Registered: Apr-06
| Posted on Sunday, April 23, 2006 - 07:26 pm: |
Where can i get the Durabrand Home theater system ht-395? |
New member Username: Suzywear
Standish,
Michigan
Post Number: 1 Registered: May-06
| Posted on Thursday, May 18, 2006 - 04:28 pm: |
I love my Durabrand Home Theatre System STS98RW. I bought the display model WITHOUT the remote control....I didn't think this would be a problem, but when I hooked it up I found the SUBTITLE button is "ON" and now I have no way to turn it off. I knew I would need my receipt for the unit, so I put in a safe place..now can't find it. Or I would have the company send me a new remote under warrenty. ANYWAY does anyone know if I can use a universal remote...and what kind. I have a Phillips universal and it doens't list Durabrand as a brand in it's codes. |
New member Username: 5hawk1985
Post Number: 1 Registered: Jun-06
| Posted on Sunday, June 11, 2006 - 02:54 pm: |
I have a durabrand tv and on the screen it has a message, EEPROM ERROR PLEASE CHECK, any idea what this means?? Other than the message the screen is black and the tv will not turn on or off. Thanks!! |
New member Username: Jeaux_jeaux
Post Number: 1 Registered: Jul-06
| Posted on Saturday, July 15, 2006 - 02:14 pm: |
Go to durabrand.com, there you'll find the remote you're looking for. It's the first one on top of the page. |
New member Username: Midevilone
Post Number: 1 Registered: Aug-06
| Posted on Tuesday, August 29, 2006 - 10:54 am: |
Try these remote codes for Durabrand tv's This one (10463) worked for my DWT1304 Durabrand 10463, 10180, 10178, 10171 |
New member Username: Austin3028
Russell,
Kansas
United states
Post Number: 1 Registered: Jan-07
| Posted on Friday, January 12, 2007 - 05:10 pm: |
i have the durabrand sts98rw home system in abox with dvd cant find the code. does a code even exist for a universal remote |
New member Username: Slimed
Post Number: 1 Registered: Mar-07
| Posted on Saturday, March 24, 2007 - 11:11 am: |
how do i get the playstation2 to work on surrond sound how to get tv to work on the surrond sound dvd player works but not tv |
New member Username: Bjawilliams
Post Number: 1 Registered: Nov-07
| Posted on Wednesday, November 28, 2007 - 05:29 pm: |
I just bought a RCA rtd215 home theater system and I hooked it all up, all the speakers work well but when i have the dvd player on trying to watch a movie there is a black line rolling from left to right across my screen |
