Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > 2.1 to 5.1
Author Thread: 2.1 to 5.1
Username: Devg
Chennai, Tamilnadu
India
Dear members,
I have a pioneer DVD Player with 2.1 output. The model no is 366 S.
I am new to this Home theater concepts.
I wanted to go for a 5.1 DTS, Dolby digital home theatre speakers.
But all the shop owners told me, I cannot have 5.1 effect with my system.
My player give 2.1 analog output, a digital output and co axial out also.
With the digital output, can I enjoy a 5.1 Effect?
If yes,
what are the hardwares i require?
Username: Levike
Cathedral City, California
Post Number: 12
Hi, If you are using Digital outputs you can enjoy 5.1 Effects. You never use the analog output for home theater, only use the analog outputs if you are listening to SACD's
Try a Digital Coax, those are better, but Optical is good too.
The only other thing you need is a Dolby Digital / or DTS receiver for this to work.
Username: Devg
Chennai, Tamilnadu
India
Hi, here in india the receivers and speakers , if you buy separate, it will be very costly.
Is there any 2.1 to 5.1 converter available in market?
Sorry I do not know much about this.
Username: Thanikai
Hi Devanand, i'm also facing the same. r u got the 2.1 to 3.1 receiver
Username: Thanikai
Hi Devanand, i'm also facing the same. r u got the 2.1 to 5.1 receiver
Username: Project6
Post Number: 1266
Yes but you will still need a receiver.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > 2.1 to 5.1 [ « Previous ] [ Next » ]
