Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Subwoofer Advice
Author Thread: Subwoofer Advice
I have a small apartment, but a big subwoofer. So that the sub is out of the way, I put it next to the couch (where I watch tv). The sub is sandwiched between a wall and the couch with only a few inches on either side. My qestion is, is this a home theater mistake?
Any advice from you experts out there would be very much appreciated!
Derek
If the driver faces down or forward and the crossover is low enough, it should be OK.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Subwoofer Advice [ « Previous ] [ Next » ]
