Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Pioneer 55txi - USB audio cutting in/out
Author Thread: Pioneer 55txi - USB audio cutting in/out
My audio from my laptop, when hooked up via a USB 2.0 cable to the 55txi, the audio cuts ins and out during playback. Per Pioneer support, I got a new cable and also downloaded the latest driver for my laptop's sound card. Still cuts out. Anyone else out there have the same problem and able to fix it? Please let me know.
Thanks. Mike. mkcruz@bellsouth.net.
Username: Project6
Post Number: 1131
are you playing back mp3s? If you have a lot of other programs running in the background, this will cause your music cut in and out.
MikeCruz
Yes, mp3s playing back using the iTunes software on my PC. I've had only iTunes open and the audio still cuts in and out.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Pioneer 55txi - USB audio cutting in/out [ « Previous ] [ Next » ]
