Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Wires/Cabling Question
Author Thread: Wires/Cabling Question
Aaron
Hello,
I have a Pioneer Elite 53TX Recviever, 47A DVD/SACD Player, B&W 601 S3 Fronts, LCR60 Center, LM1 Rears, and a Paradigm PSW10 Sub.
I need some advice. Based on the level of my equipment I am not sure what cables / wire to use.
I have run high quality inwall rated 4 conductor wire to the rears. I am also using a Monster cable optical connection to my Yamaha CD player, A MTI coax digital cable for DVD-RX Audio, a Monster 300 Series Subwoofer cable.
I still need component video cables, RCA cables to connect my VCR. What brand/model of cables would you recommend?
I also need to connect the front speakers and center speakers. I would like to biwire them. Any recommendations here?
The front/center speakers will be within 10 feet of the receiver and all of the componets are within 6' of the recevier/TV.
I have been looking and have no idea how good of cable to buy based on my setup?
MeElite
I would recommend the MTI Terminator cables that are setup and terminated for biwiring. Look on ebay and you might get 3 for cheap. They are worth it. You have too nice of equipment to waste on cheap cable. Consider the monster 200/300 series for the rest of the cables.
What does that mean, biwire?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 30, 2004 > Wires/Cabling Question [ « Previous ] [ Next » ]
