7.1 surround sound
Can anyone tell me if this exists?? Also if it does what is major differences in sound and equipment.
Thanks
It does exist. Going back two steps we had 5.1, which consists of 5 full range speakers (2 front mains, 1 front center channel and 2 rear surrounds) along with a low frequency effects channel (the .1). Most DVDs are encoded in either DTS 5.1 or Dolby Digital 5.1. More recent is 6.1 which adds a center rear, to make transitions more natural. More and more receivers are available with this, but not many movies. With 7.1 you have the three front speakers, two surrounds at about the same location as the listener and two rear surrounds. As far as I know (and I could be wrong) there are no 7.1 encoded movies yet, so the receiver has to decode it from 5.1 or 6.1 sources. I haven't heard it so I can't say whether it offers much of an improvement. I would assume that more will be available in the future, but who knows. Also keep in mind that as you add more speakers you need more real estate to fit those speakers.
dew
i am hooking up my theater system for 6.1 surround, but using a 7.1 reciever. is there a way to combined the left and right channel speakers to one channel or just use on of the channels
howlswolf
check your reciever setup you might have the option to switch between 6.1 and 7.1 i have this option on my sony 995
lol you have a sony receiver
Benson
Does anyone know how i can hook up my PS2 on my creative 7.1 sound system.
Username: Project6
Post Number: 430
use the digital output of the PS2
