Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Help! Just got Sony Wide Screen and ...
Author Thread: Help! Just got Sony Wide Screen and DVD Home Theatre, return and get DVI?
sanee
Ok, I just got a Sony 51'' Widescreen Projection HDTV (KP-51WS510) and the Sony DVD Home Theatre System Reciever (DAV-BC150). But now I'm hearing a lot about DVI and how it's alot better than component when using DVD. Should I return the DVD Home Theatre system and get one with a DVI output or just stick with component? I'm slightly dissatisfied with the DVD player as it does not have audio outputs so the TV speakers go to waste and the 5 surround speakers are it.
Help!! Tell me what to do.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Help! Just got Sony Wide Screen and ... [ « Previous ] [ Next » ]
