Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Need advice on receiver-speakers set-up
Author Thread: Need advice on receiver-speakers set-up
Username: Jonas
I am quite new in audio set-ups. I recently bought a Marantz SR5300,
Def-tech's prosub 100TL, and Wharfedale's Diamond 8.3. Please
enlighten me on:
1. Center - since I am on a budget, which do you think is best and
would match well with my existing Marantz/Deftech Prosub/Wharfedale
Diamond 8.3: a)Wharfedale's Diamond Center b) Deftech's Procenter 100
c) Deftech's Procenter C2?
2. Subwoofer - If the crossover is 40hz to 150hz, how can the spec of
my Prosub 100TL of as low as 19hz be reached? Is connecting with a y
connector to left and right better than using the single LFE
connection at the back of the subwoofer?
3. Break-in - Is it true and necessary? How long?
I plan to buy my center speaker on the 30th of the month since I dont have the bucks to buy them all at once after which
I'll start looking for my surrounds next month...
Username: Swifte
Philadelphia, PA
I just purchased a Denon AVR3805 and desperatly need assistance in hooking it up.
If anyone can shed some light on this for me, please contact me off line at
swifte546@aol.com
I live in Philadelphia, PA
Thanks much!
Jere
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Need advice on receiver-speakers set-up [ « Previous ] [ Next » ]
