Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Car subs with home theater??
Author Thread: Car subs with home theater??
Username: Joe_f
Ok, I am scrapping my old car audio system and was wondering if it were possible to use the subs from the car and hook them up to an in-home audio setup? For convenience sake, I'll say that I already have a legitimate home receiver, speakers, sub amplifier, but no sub.
Is it possible just to hook the car subs up to the home theater? Or (I'm assuming) are there drawbacks and precautions that should be taken before even attempting this?
Anyone that knows anything of the sort please help! Thanks a lot.
-Joe
johnm
What are you going to use to power the sub?
Remember car audio speakers usually have a very low impedance rating, meaning you can burn out a home receiver or amp that doesn't handle that ohm load.
Also, your sub enclosure is important. You'll probably want some type of bandpass box.
Username: Joe_f
I am using a MA-1A sub amplifier.
I have been warned before about the ohm load. Is there any way to possibly lower the ohm output by the sub to make it more "home entertainment" friendly?
And, the enclosure should be fine, the box is pretty nice.
Thanks again,
-Joe
johnm
If you want to do is actually "raise" the ohm load. You can do this by either running an in-line resistor along the speaker wire (not sure really what this will do to the sound) or better yet if your using two subs and want to double the ohm load you can run them in series. That is running speaker line from amplifier+ to sub1+, sub1- to sub2+, sub2- back to amplifier-. You lose some db this way since your now powering 2 subs but the impedance load is safe.
Username: Joe_f
Thanks a ton john, I will give that a shot. Really appreciate all your help, will let you know how it goes =)
-Joe
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > Car subs with home theater?? [ « Previous ] [ Next » ]
