Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > NAD T773
Author Thread: NAD T773
Username: Samo
Help!!
Back of NAD T773 terminals for front speakers reads "L" and "R" (IN THAT ORDER, NOT "R" and "L" as most A/Vs have). Only problem is if you setup as reading from the back (ie. connect the front speaker on your left to the L terminal) then sound moves across the screen in the opposite dierction. So in order to fix you obviously connect the front left speaker into the L terminal. The only problem with this is that the speaker cables MUST CROSS over!! I have contacted NAD and they were not very helpful. Is anyone else having these setup problems?!??
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > NAD T773 [ « Previous ] [ Next » ]
