Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 16, 2003 > HELP PLEASE
Author Thread: HELP PLEASE
Dimitris
Hello Everybody. I 've recently bought an "AUDIO PRO" home-theater speaker set which i currently use with an old Dolby Pro Logic Receiver of "SANSUI". The impedance of all speakers is 4ohm while my receiver specifications allow only the use of 8ohm speakers. There are no problems so far but as far as i know i put both my speakers and receiver in danger. I 've decided to buy a new A/V receiver. Does anybody have "an abpproximately 500-600$/€" suggestion? How about a New Sony STRDA 2000ES or something Similar? Should anybody know anything about the relation of Speaker Ohm Impedance and Receiver Acceptable Specifications please let me know.
elitefan
You will be hard pressed to find a good receiver in this price range that can safely drive a 4 ohm set but best bet would be a NADT742 or another NAD model refurbished. Hawk should have some suggestions also.
Dimitris
Thanks a lot elitefan. I had already read some good reviews relating to NAD T742 and your opinion will definitely help me to move ahead. Thanks once again.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 16, 2003 > HELP PLEASE [ « Previous ] [ Next » ]
