Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Novice from Holland on Mirage Omnisat
Author Thread: Novice from Holland on Mirage Omnisat
Guys,
I'm a novice to this but I'm interested to hear some advice on what you think about the Mirage Omnisat speakers and if they are any good what receiver I should buy with it. Should I get a different sub-woofer (like REL Quake II) and should I get 2 Omnisat Micro's for the rear.
The Mirage Omnisat is a great little speaker. You defiantly need to use them with a subwoofer though. The sound is amazing for such a little speaker, and they are very solidly built. I would recommend the LFE-100 or 150 depending on the size of your room. We sale the Omni-sats with Pioneer Elite receivers like the VSX-43TX and VSX-53TX. I wouldn’t get the micros unless you are on a budget.
www.CustomSoundCo.com
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through February 18, 2004 > Novice from Holland on Mirage Omnisat [ « Previous ] [ Next » ]
