Thread: Bose Cube Speakers |
| Posted on Friday, October 24, 2003 - 10:09 pm: |
I have a lifestyle 20 system and the bose speakers have a male square receptical with two post in the back. I am wanting to use monstor cable for the speakers, but I will need a female receptical for the speakers. Any thoughts would be appriciated |
Anonymous |
| Posted on Monday, October 27, 2003 - 10:00 pm: |
"any thoughts?" no highs, no lows, must be a bose! puting monster cable on a bose cube speaker is like puting racing slicks on a ford escort.anyone agree? |
james watson Unregistered guest |
| Posted on Thursday, January 01, 2004 - 11:33 am: |
does anyone have any advice as to whether a good sound can be obtained by putting two bose cube speakers on a teac reference 300 system. I just can't see how those tiny things are gonna be worth the cash, even though assured by the sales rep that they are. |
New member Username: Hawke
Post Number: 1 Registered: 01-2004
| Posted on Wednesday, January 14, 2004 - 10:04 pm: |
You really don't need Monster cables for those speakers unless you really like the look of Monster cables. They won't affect the sound of the cubes. I'd recommend perhaps getting some 16 gauge cable from Home Depot or Radio Shack. Don't feel bad, but don't spend more money on something you don't need. Remember, even Bose ships their speakers with 18-24 gauge raw cabling. |
New member Username: Absolut
Post Number: 3 Registered: 01-2004
| Posted on Thursday, January 15, 2004 - 11:31 am: |
You can call Bose and tell them that you want to run your own speaker wire for your Lifestyle 20 system. They should be able to ship you out an adapter that will plug your speaker wires into one end and have the plugs on the other to go into your bass module. |
