Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Klipsch VS. Polk
Author Thread: Klipsch VS. Polk
Lori
I am starting my HT system. I just bought a Denon AVR-4802R and I am trying to decide between the Polk RTi8 Series or the Klipsch reference 50 series. Does anyone have a suggestion?
Username: Shantao
Post Number: 19
Lori;
I would think either would pair well with your denon. Personally, I like the Klipsch, but that is my opinion. I tend to like the sound brighter (not overly so) and I perceive the Klipcsh as being a bit brighter.
To me the Polk's are a bit warmer.
They are both really good speakers and I think you would be happy with either.
Hope that helps.
Duane
I think that there is a very slim difference between Klipcsh and Polk. My personal favorite are the Klipsch, only because I think they have a little clearer sonud. not that Polk does,nt have a clear sound but Quite that of the Klipsch.
Username: Elitefan1
Post Number: 580
To my ears Denon and Klipsch are way too bright together. Polk maybe also. Denon's have a thin, detailed sound and benefit from a mellower speaker. Check out Paradigm, PSB and B&W.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Klipsch VS. Polk [ « Previous ] [ Next » ]
