Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Onkyo TX-SR601 with what speaker?
Author Thread: Onkyo TX-SR601 with what speaker?
Username: Colala7735
Post Number: 10
I'm going to buy an Onkyo TX-SR601 (85W/CH). Any suggestions on speakers? Right now I only want to consider two front speakers. My total budget is~400 for two speakers. Thank you!
http://www.onkyousa.com/model.cfm?m=TX-SR601&p=f&class=Receiver
Post Number: 11
How about Fluance AF-F3?
http://www.fluance.com/fldycothhisp.html
Username: Sleepingbag
Clarks Summit, Pa
I was looking at getting something simular. But it seems that the receiver is 85W output, and the speakers can take around 120W. You may want to consider upgrading the reciever and/or downgrading the speakers. But that's just my idea(i don't know everything)
I was looking at getting the TX-SR701 and buying SKS-HT240 speakers. That would get you all the speakers for a reasonable price. I think the only major difference on the 601 and the 701 is the W output[SR601(85W/Ch) and the SR701(100W/Ch)]. The SR701 is also $50 more. I dont know if thats worth it or not......If some one does know, please tell me.
Good Luck!
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Onkyo TX-SR601 with what speaker? [ « Previous ] [ Next » ]
