Thread: Denon M-D71DVSXP HTIB |
| Posted on Thursday, June 24, 2004 - 03:17 am: |
Just bought a Denon HTIB w/ virtual surround sound. Will hook up a Direct TV receiver and a flat panel LCD TV. So, need to make the following connections: Video: Sat receiver to TV Video: Denon unit to TV Audio: Sat receiver to Denon unit Speaker wires, including Sub wire Should I pay the money for Monster Cable to replace all of the above, some, or none at all and just stick with the provided wires? Will need a power strip, so probably should invest in a surge protector. But, should I spend the extra money for a unit that is also a power conditioner (Monster HTS 800) or even the HTS 1000 which has the stage 2 conditioner (and is a nicer, mountable unit). Currently setting this system up in a 10x17 bedroom, but will probable transfer it all to a new home in about a year, so want to take that into consideration (willing to spend the extra money now if I can use the cables and/or power surge conditioner for a bigger room or even new system). Thanks in advance |
