Home > Message Board > Home Theater > Home Theater Setup & Planning > First time with LCD flat screen tv
Author Thread: First time with LCD flat screen tv
Username: Malco49
Baltimore, Maryland
Usa
Post Number: 163
please don't laugh!
ok here goes
i am considering a flat screen LCD tv to go w/direct TV.room is small 12"x6"
i will be setting between 3.5-6 ft from screen.what is best size 22" or 26" and what brand? no gaming just TV shows and sports.are the DVD/tv combos worth it?
i know i need one HDMi cable but should i get TV with more than one port capability? i may at some point use is for a computer monitor.
thanks
in
advance
Username: Mccambley
BREEZY POINT, NY
Post Number: 708
Vizio 32 inch $399
http://www.costco.com/Browse/Product.aspx?Prodid=11483027&search=vizio&Mo=2&cm_r e=1_en-_-Top_Left_Nav-_-Top_search&lang=en-US&Nr=P_CatalogName:BC&Sp=S&N=5000043 4294908733&whse=BC&Dx=mode+matchallpartial&Ntk=Text_Search&Dr=P_CatalogName:BC&N e=5000002+4000000&D=vizio&Ntt=vizio&No=0&Ntx=mode+matchallpartial&Nty=1&topnav=& s=1
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > First time with LCD flat screen tv [ « Previous ] [ Next » ]
