Home > Message Board > Home Theater > Home Theater in a Box > Yamaha YHT-790BL
Author Thread: Yamaha YHT-790BL
Username: Bafoster
Hello,
I just purchased this package and included in the box was a note indicating that the Yamaha HTR-6140BL receiver had been substituted with the RX-V463BL and "both AV receivers are identical in everyway, including the same great features and cosmetic design."
I'd be interested in hearing from anyone that can confirm (or deny) that this is an equal swap.
Thanks in advance!
Username: Bafoster
A question about the same system. The subwoofer (YST-FSW100) came with a system connector input jack (and system connector cable). This connects to a Yamaha component equipped with a system connector jack and allows the subwoofer to be powered on and off with the component it is connected to.
I was not able to locate a system connector jack on the RX-V463BL receiver. Does anyone know if the receiver supports the system connector option?
Thanks!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater in a Box > Yamaha YHT-790BL [ « Previous ] [ Next » ]
