Home > Message Board > Home Theater > Home Theater Setup & Planning > TV - Home Theater connection
Author Thread: TV - Home Theater connection
Username: Dan_dinca
Hi,
I just bought a LG TV (37LH7000) and an LG home theater system (LG HT 462DZ).I connected the DVD to TV through an HDMI cable (TV-HDMI IN to DVD-HMDI OUT).TV is also connected to one digibox (cable antena) through scart cable.
If i'm playing a movie from USB (for example) the sounds goes through home theater speakears (like expected).But the problem is: if i'm pausing the movie and i'm switching the Tv to antena (to see the tv channels) and after that go back to movie and press play then the sounds is not coming through home theater speakers (the sounds goes to tv speakers).
My question is what is wrong?Is a tv or dvd problem?
Are my connections done wrong?
Thanks in advance for your answers
Username: Mccambley
BREEZY POINT, NY
Post Number: 696
There is nothing wrong with your connection. The HDMI is passing the audio to the TV from USB it must do it with DVD. You may have to switch to another input (tuner) and remove the USB and then reconnect to right the sound.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > TV - Home Theater connection [ « Previous ] [ Next » ]
