Thread: Cable to connect tv to home theater |
New member Username: Raiderball1
Post Number: 1 Registered: Aug-09
| Posted on Monday, August 31, 2009 - 07:42 am: |
ive been trying to figure this out for awhile, the more I look into it, the more confused I get lol... My TV does not have the Red/White audio out jacks on it. It does have an orange Coax (is this the same thing as SPDIF?) which I'm assuming is going to give the sound output from my TV because I swear Ive tried everything else. Only problem is my Home Theater system (Samsung HT-Z410) doesn't have the other end of the orange Coax cable. It's got a spot for components, and the red/white audio and yellow video. It also has a digital audio input (optical). Is there any way to connect the orange coax to the digital optical input? (If that made any sense) or is there another way that I'm overlooking? Any help would be much appreciated! Thanks, Erik |
Post Number: 2 Registered: Aug-09
| Posted on Monday, August 31, 2009 - 07:44 am: |
oh, and I only have a coax cable to connect my cable to my tv (don't have a box) so i can't go optical to optical |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 866 Registered: Feb-08
| Posted on Monday, August 31, 2009 - 08:01 am: |
Greetings Erik, The best thing to do, as you may have already guessed, would be to get a cable box but you can do the digital coax to optical conversion: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302 &p_id=2948&seq=1&format=2 |
