Home > Message Board > Home Theater > Home Theater Setup & Planning > Need Advice With In-Ceiling Surround ...
Author Thread: Need Advice With In-Ceiling Surround Sound (NOOB)
Username: Cdawg1984
I have a large living room (like 600sq ft) with a 18' vaulted ceiling above the T.V sloping down to 12' above the seating area. The left of the room has a 3' high wall and is open to the kitchen, the right side of the room has a full wall with the hallway and front entrance.
I know the size and layout causes some chaos for decent surround sound but my wife just decided to change her mind (yet again) and does not want any speakers showing in our new house. Also she doesn't want them in the wall either.
Can a guy get some decent sound out of in-ceiling speakers with this set-up for around $1500-$2000 or should I try to convince wifey to go for some in-wall speakers. I want to go for 5.1 but have the option to upgrade later on.
Please dumb it down for me....this will be my first experience with hidden speakers.
Thanks all
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 864
Greetings,
I might suggest a surround bar of some sort. Polk makes several and many other manufacturers have jumped on board because they solve so many problems like the one you are dealing with.
http://www.polkaudio.com/homeaudio/surroundbar/index.php#overview
Username: Cdawg1984
Thanks for the input.
I have been doing some research and from what I can tell a surroundbar relies on a 4 walled room for the sound to bounce off and create a virtual surround sound effect.
If I am way off please let me know otherwise.
Username: Mccambley
BREEZY POINT, NY
Post Number: 692
A possible solution for you could be a speaker that uses a Pivoting Woofer & Tweeter for in ceiling speakers. The 18 ft part is high up. Niles and Speakercraft are two options I know of.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > Need Advice With In-Ceiling Surround ... [ « Previous ] [ Next » ]
