Home > Message Board > Home Theater > Surround Sound > Help on setting up surround sound
Author Thread: Help on setting up surround sound
Username: Mikep3396
So I have a pretty old reciever, and currently ive had the rca cable plugged in from the comcast cable box to the receiver. This current setup sounds good but im goin to college and I wont have a cable box just basic cable. So I took the cables out of the comcast box and plugged the red and white into the tv to test it out. I get sound but it just doesnt sound as good as when it was plugged into the cable box. It sounds like most of the sound is now coming out of just the center speaker. Any help?
Username: Mccambley
BREEZY POINT, NY
Post Number: 687
What kind of TV? You may not have the rca jacks plugged in correctly. It sound like you have a mono connection only, either right or left is not correct.
Username: Mikep3396
ok so i got a new receiver and the surround sound from the 360 sounds great via the optical cable. My only problem is with the cable tv, I have the optical hooked up from the tv to the receiver and the sound only comes out of the center speaker. The surround sound works when I plug in the rca cables from the cable box to the receiver. The problem is I wont have a cable box to use in college just the cable from the wall. Would I need a vcr player to plug the cable into from the wall then into the tv?
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 854
Greetings Mike,
If, once you get to school, the TV speaker out jacks do not work then yes, a VCR could solve your problem.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Surround Sound > Help on setting up surround sound [ « Previous ] [ Next » ]
