Thread: Fix old or buy new |
New member Username: Durbin
Post Number: 1 Registered: Aug-09
| Posted on Wednesday, August 12, 2009 - 09:35 pm: |
I have a Sony STR-SE501 but am having trouble getting the front right and left speakers to get a signal. I tried hooking up my center speaker which works to the front just to test and got nothing. Is this a good receiver? Is it worth fixing? It cost like 500 dollars 7 or so years ago. Is it worth it to try to fix it or should I just get a new HTIB system. I don't want to spend more than 200 dollars for a new one. I have UVerse with HD service and a new 42 inch HDTV and want home theater working right. Thanks! |
Post Number: 2 Registered: Aug-09
| Posted on Thursday, August 13, 2009 - 12:08 am: |
The rear speakers receive no input either. |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 686 Registered: Jun-05
| Posted on Friday, August 14, 2009 - 02:48 pm: |
This is a receiver that is part of HTiB. I would not recommend that you fix this receiver. Buy a new receiver, not a HTiB, possible one of last years models for your $200and reuse yor speakers. |
New member Username: Eatisa
Post Number: 8 Registered: Jul-09
| Posted on Friday, August 21, 2009 - 04:43 am: |
no it would be good if you get a new one try Techsava, you can get a lot of better receivers and other accessories, at the price you are looking |
